EM TuningMonster Motorsport
    Sep 2009
    West london
    379
    fault code help please
    hi guys had an engine management light come up the over day so i did a complete scan and this is what has come up
    any help would be great thanks will
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Address 01: Engine Labels: None
    Control Module Part Number: 8N0 906 018 J
    Component and/or Version: 1.8L R4/5VT 0004
    Software Coding: 10710
    Work Shop Code: WSC 01236
    Additional Info: WAUZZZ8LZ11000797 AUZ7Z0A1825268
    VCID: 38742ABE74099DDC
    8 Faults Found
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-00 - -
    17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
    P1116 - 35-00 - -
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
    P1103 - 35-00 - -
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUZZZ8LZ11000797
    Part No: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    8 Faults Found
    P0130 - 35-00 - -
    P1116 - 35-00 - -
    P1103 - 35-00 - -
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E783CA6562DA3EC
    1 Fault Found
    00778 - Steering Angle Sensor (G85)
    27-10 - Implausible Signal - Intermittent
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8L0 820 043 K
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00041
    Shop #: WSC 01236
    VCID: 3064129E9C79459C
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 5008
    Coding: 01104
    Shop #: WSC 01236
    VCID: 458A534A33FBF034
    3 Faults Found
    01218 - Side Airbag Igniter; Passenger Side (N200)
    32-10 - Resistance too High - Intermittent
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    00588 - Airbag Igniter; Driver Side (N95)
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 L
    Component: AB-KOMBIINSTR. VDO D12
    Coding: 01444
    Shop #: WSC 00001
    VCID: 3C7C36AE4031B1FC
    1 Fault Found
    01176 - Key
    07-10 - Signal too Low - Intermittent
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F46E122F1E7CAE4
    1 Fault Found
    00526 - Brake Light Switch-F
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 01236
    VCID: 2F6611E281475A64
    5 Faults Found
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    00991 - Interior Lights
    28-00 - Short to Plus
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    have you had a flat battery?
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    Sep 2009
    West london
    379
    I did have about month ago and changed it as it was stuffed
    But the engine management light only come on a week ago
    Sant.'s Avatar
    Tetbury, Gloucestershire
    50
    Your best bet is to reset the codes then scan again after a drive...
    Sep 2009
    West london
    379
    Are do that then see how it goes
    Cheers guys
