Hi,
The heater in my car is blowing cold air, after reading a few posts on various forums I changed the thermostat which helped keeping the engine temperature at a normal level but the air coming from the heater is still cold.
I have read it might be the heater matrix or the connections at each end, do any of you have an easy way to check the connections without dismantling the entire dashboard? Or maybe you have any other suggestions...
Thank you
Thank you
