EM TuningSky Insurance
Results 1 to 10 of 10
    talentwalsh's Avatar
    May 2010
    Galway
    139
    Did N249 bypass and car ran like poop.
    Howdy y'all
    As the title says I did the bypass yesterday while installing all my new shiny silicone vac hoses, as i had some tubing left over, and the car ran like a bag of ferrits in a tubmle dryer. Any reason for this, does the ecu need time to learn the new system? I put the OE stuff back on again and it ran fine again. Its an AMK so it should be a direct hose from the DV to the inlet?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    How did you do the bypass? I.e. did you remove all the hoses to the n249? Did you leave the n249 valve connected or not?
    May 2010
    Galway
    139
    Yep, removed all of the hosing connecting to it and left it plugged in. I used 5mm hose, maybe it was a bit loose?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    5mm is way too big, 3mm max id say, did you secure all the vac hoses?
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    Did you keep the N249 plugged in but tucked away?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    May 2010
    Galway
    139
    Ya, kept the N249 plugged in. No I didnt secure it as I didnt have any jubilees small enough, felt a pretty snug fit though, even when removing it felt fairly tight, but id say that was the problem though. Thanks for that.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,063
    This isn't meant to sound rude, but you must have done it wrong. What did you do with the feed to the n112? Did you put a check valve in line to it?
    May 2010
    Galway
    139
    Its an AMK, doesnt have an N112, its direct to the mani.
    jdas03's Avatar
    Jun 2009
    Surrey, UK
    597
    Yer AMK is straight from DV to Mani, i have AMK engine and i didnt notice much difference except it was far smoother at low speeds, definetly didnt make it worse thought :-S
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Yeah, I would say this is the first reported problem with this mod... See what happens when you have slightly tighter hosing.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
