EM TuningMonster Motorsport
Thread: Over reving
    Jun 2009
    36
    Over reving
    Hiya when Iam out driving sometimes between gear changes the engine will over rev is this normal or is somthing wrong please help thanks
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Clutch switch
    Jun 2009
    36
    Is it easy to change and how much will it cost? Thanks
    NoggyS3's Avatar
    Oct 2010
    Southampton
    242
    My s3 also revs slightly between gear changes. Gets on my tits!
    Sandip is it easy to change the clutch switch?
    Wanted : Stainless Cat-Back monies waiting
    Standard Nogaro Blue 21O AMK S3
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Not changed one personally but i wouldn't say it was that difficult once the lower dash trim is off. As for price i'd say it could be near the same price as the brake switch, around 5
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    yeah I would start with the clutch switch as its the cheapest option
    they are a plunger type switch
    there pretty easy to change.
    get on the floor under the steering wheel
    you will see the clutch switch at the top of the clutch pedal
    to remove it unplug the cable
    then turn the main body of the switch and it will come out
    reverse to fit the new one
    mine was nackered and didn't go smoothly in and out
