JMB RetrofitsVolks Autos
    Aug 2010
    bradford
    1,252
    how to reset throttle body on vagcom
    as above ta
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Copied from the Ross-Tech Site:
    Throttle Body Adaptation:
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Measuring Blocks - 08]
    Group 060 (Group 98 in non-DBW engines)
    [Go!]
    [Switch to basic settings]
    Once you do this you will see the top right display say ADP RUN. The TB
    adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in basic mode for about 30 seconds, then switch back to normal settings and you're all set.
    Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
    Imteyaz.
    Aug 2010
    bradford
    1,252
    tar mate ill get it done and see if theres any changes
