JMB RetrofitsBadger5
Thread: spark plug help
    gussyldr's Avatar
    Oct 2010
    East London
    93
    Question spark plug help
    hi all couple of questions
    (1)does any one know if eurocarparts, gfs or halfords sell ngk bkur7et?
    (2)also can some one tell me what size coupling ill need to fit my air filter to the mass air flow meter?
    (3)and what have pepole done with there ignition amp after fiting a induction kit or air filter?
    thanks
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    1. Im not sure so it would be best giving them a ring.
    2. I think its 70mm although i could be wrong.
    3. It needs to be attached to a metal surface a lot of people have made a bracket up for it and it also needs thermal paste between the contact surfaces. The reason its on the airbox is so it is kept cool so keep that in mind.
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    70mm is A3 80mm is S3 for the coupling. not sure about the plugs.
    regarding the ignition amp u dont really want it on the metal causing vibrations and wearing away the surface taking away the thermal protection on the heatsink part. Just cable tie it to ur induction pipe and itll be ok. if u have a cold air feed point the ignition amp in that direction.
    Although if not it will be fine with a good even layer of thermal paste between the heatsink and ignition amp
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    gussyldr's Avatar
    Oct 2010
    East London
    93
    thanks for the replies
