JMB RetrofitsBadger5
Results 1 to 14 of 14
    From Show... to GO
    Nov 2010
    Stafford
    436
    Xenon Level Sensor Rod Replacement?
    hey guys, got the factory fit xenon's on my S3, and looked underneath, and on the passanger side there are two level sensor rods, one at front one at back.
    the front one is bent, but not buckled, so im not sure if thats how it's supposed to be? or should it be straight?
    and the rear one is snapped completely, so i need to know where i can get a replacement?
    i think its affecting the headlight aim, as the lights are very low aimed, they dont light up much of the road infront of you, which makes sense if the rear rod is snapped.
    any help much appreciated, cheers Jon
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    This is weird, I've literally took a picture of mine just then as it's bent, because someone posted there lights being low. This is likely the problem. I'm just going to straighten mine out. As for the other you should get one from Audi. Hope it's not much
    From Show... to GO
    Nov 2010
    Stafford
    436
    yeh, but i read in another thread that it should have a bend in it, but cant find that thread so wanted to confirm it.
    i want to get the back one sorted though.
    and may then have to adjust the headlights manually if there still as rubish
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    The front rod is meant to be bent... don't try and bend it straight...
    <tuffty/>
    From Show... to GO
    Nov 2010
    Stafford
    436
    I thought so, i hope karl reads this in time haha
    just need to find a rear one now!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    Ahhh cheers for that couldve made a big mistake there.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    I'm stumped then. When I turn the car on they raise up, but moving along I can watch them go down. I haven't checked the back arm yet though
    From Show... to GO
    Nov 2010
    Stafford
    436
    could be dodgy motors then, could disconnect them and adjust the lights manually,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by coyle View Post
    ...the rear one is snapped completely, so i need to know where i can get a replacement?
    Is it the arm of the sensor or the actual rod? the arm is easy to break if you are not careful when changing the springs on the back (which if yours is broken is how I suspect that happened as its not a part that breaks without human intervention)
    ...i think its affecting the headlight aim, as the lights are very low aimed, they dont light up much of the road infront of you, which makes sense if the rear rod is snapped....
    Plausible, a scan of faults codes would also confirm this as I am pretty sure a fault code will be thrown for this..
    Another common fault is the headlight adjustment motors... they stop working and the headlights aim low...
    <tuffty/>
    From Show... to GO
    Nov 2010
    Stafford
    436
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    from memory its the rod which is top to bottom. not the arm which the top attaches to.
    i'd need to check again to be sure, as i just noticed it wen it had my sump off, so didn't give it a huge ammount of attention.
    From Show... to GO
    Nov 2010
    Stafford
    436
    does any one have any idea of what the correct term for the part is? it would help to know what it's called when searching haha
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    im guessing the rod is part of the 'xenon level sensor' assembly
    S3KO4's Avatar
    Aug 2009
    London
    850
    My front one is completely broken, so I don't get any of the auto adjust when I get in the car. however when the tank runs low on fuel the left beam drops massively this affects the hi beam as well I have used Vagcom on it and I managed to move them up and down. which is a nice bit of kit
    I think they are expensive, second hand around 50-70GBP for each one and probabily double that for new.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    From Show... to GO
    Nov 2010
    Stafford
    436
    surely because its just my rod thats broke, and not the arm, i would just weld a tube/sleeve over it?
