Hi all,
Firstly my headlights are pointing about 10feet in front of my car and I therefore can't see anything at night time. Through searching I note this can be adjusted via vagcom, but as I don't have it, is there anyother way of fixing the issue.
Secondly, my S3 (BAM) has developed a sort if quick juddering as soon as the turbo is on song at around 3000rpm. It drives fine below these revs, but as soon as you get to 3k, the car judders and doesn't go much quicker. Initially the EML didn't come on, but after letting it judder for quite a few seconds, it then started to flash but went off again as soon as I started driving normally again.
I had my first coil go last month and this doesn't seem the same, so I was wondering what this could be. Again, I don't have access to Vagcom and sadly the nearest VAG specialist is a good 25miles away (I live in south oxfordshire).
Many thanks in advance
