Chris NottBadger5
Results 1 to 11 of 11
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    S3 Under Boosting, Changed MAF, no improvement :(
    Okay so some of you may know i took my S3 up to leicester at RTech for a Stage 1 remap a couple weeks back.
    Couple long stories short it didn't end up getting mapped because they found that the car was down on power (only producing 198hp) and was significantly under boosting.
    A few things were ruled out (N75, actuator etc) and i was sent away with the advice of changing the MAF sensor and possibly the MAP sesnor.
    I'm no mechanic and only have basic knowledge of engines so this was all new to me but i ordered a new genuine MAF and fitted today in hope of a power improvement.... There was none
    Has anyone had this problem and may have and suggestions for me as i need this sorted before i can get it mapped
    RTech is a good 3hours each way for me and i don't know anyone with VAGcom to log requested boost vs actual boost to check if it's boosting correctly.
    Any help guys??
    Fahim's Avatar
    Dec 2009
    Wanstead
    280
    It could be a boost leak?
    Have you tried making a DIY boost leak tester and using a compressor to pump your system in with 10-15 psi and listening to leaks?
    I made one myself last week using a 3inch to 2inch rubber coupler, a PCV cap (both from plumbing shops 7 in total) and a free tire valve from my local tire shop.
    Bish bash bosh, and you can check boost leaks in a jiffy.
    Things to do: Lower on coilovers, spacers, front end respray and a full correctional detail!
    Living a little!
    London
    181
    MAF is definitely the first thing to rule out and does it a world of good to change anyway and cheap to replace. Making any noises, hissing? Could be loosing boost. Split hose, turbo?
    When did it have a Service. Plugs, oil, filter etc?
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    It was tested at RTech with a smoke test for leaks which gave no leaks at all :-|
    A mate of mine that works at VW seems to think a split vac hose could cause this issue? Is that right??
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Have you got a boost gauge on it bud? What is it boosting?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Really needs data logging to find the issue have youlooked on the vcds user map?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by SamiG View Post
    Split hoses can cause issues, but it would be very unusual for it to cause under boosting of the turbo. Split in the actuator piping/N75 piping/DV piping would generally cause it to overboost.
    Homer Simpson
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    It was serviced 3 weeks ago with oil/filters/plugs/fuel filter etc
    I don't know anyone with VAGCOM to do the datalogging
    MAF has made no difference at all :-|
    And no, i do not have a boost guage on it either...
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Thanks dude!
    I PM's a couple of people
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    Could be electricaly related i.e. coilpacks. VCDS will show you the way though.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
