Monster MotorsportChris Nott
Results 1 to 18 of 18
    Aug 2008
    114
    Rear window washer not working?
    as title, pump can be heard working, fronts work fine. Its not because its frozen!
    Thought i would ask on here if there are any common places where pipes come off or get blocked before i start looking?!
    many thanks
    Alex C's Avatar
    Lizard, Cornwall
    2,560
    mine has recently stopped working as well, since its got really cold, but its not frozen either, its had ages to thaw out now
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Aug 2008
    114
    really annoys me as im constantly looking out me back window so like it clean! and in this weather with the roads it gets filthy!
    KB
    KB's Avatar
    Jul 2010
    Inverurie, Aberdeenshire, United Kingdom
    195
    theres a connection under the bonnet, its in a black plastic trunking with cables in it on the right handside of the engine bay, prob best to take out the airbox to get at it! then once that one is fixed the one in the boot will go! its just next to the cd changer and subwoofer in the boot!
    Oct 2010
    Port Glasgow
    283
    there is also the connection at the rear wiper motor mine has come of 4 times in the last cpl of months its doin my head in ,
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    353
    the connection under the bonnet went on mine and so did the connection onto the motor on the boot lid
    I ended up replacing the hose from the motor round to the connection under the subwoofer with a bit of 4mm silicone hose as the end onto the motor had split and wasn't staying on at all, after all that i found it still leaked from the washer motor and that the wee brass pipe had corroded and snapped so got a wee repair kit to sort that
    its all working now though :-D (touch wood)
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    mine doesn't work either, anyone got a pic of what pipe it looks like ?
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    It always happens in the cold weather... the jet freezes up and when you flick the switch to clean the screen the pressure builds up inside the pipe because of the frozen jet and eventually the pipe bursts at the weakest point, normally in the trunking behind the airbox under the bonnet.... does anyone know if the washer jets are heated on the A3 ??? they used to be on the older Audi's but it was a common part to fail as they were on all the time with the heated mirrors.... might look into this as a mod if they are not what with this cold weather looking like it's here for a while
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Mar 2008
    Oldham, Manchester
    1,089
    To answer my own question
    1999 AUDI A3 1.8SE pair heated front washer jets & pipe on eBay (end time 11-Dec-10 14:09:27 GMT)
    I bet the rear isnt though... possible mod to be had there then
    Oct 2010
    Port Glasgow
    283
    cant answer your question markyboy but ill post this link here its quite a big thread that leads to others but very usefull for anyone who needs to locate the points where the fluid pipes join , i sourced all mine except the one at the sub location and cable tied the joints up , worked fine on the one under the air box and in the trunking but the rear motor one is an absolute cnut keeps popping off no matter what i do so leads me to think its not heated as it always produces a very weak leak onto the rear window just before it stops alltogether so reckon its freezing on the outside , short of using less water and more antifreeze i dunno how to fix it so best read through this threads and make yer own mind up
    washer fluid leak!
    a3tdi2001's Avatar
    437
    Just wondering if it's possible to get to the connector under/behind the subwoofer without removing the side panel trim?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Quote Originally Posted by a3tdi2001 View Post
    Yes you can get at it without removing the subwoofer, I had to do mine recently and it's not too bad once you feel for the pipe.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    a3tdi2001's Avatar
    437
    Cheers.
    Is it below or up behind the unit? I take it, it's just a case of pushing both ends back together?
    Oct 2010
    59
    yeah where abouts is it in relation to the speak box just had a look at it and dont fancy tearing my boot to pieces to get to it!
    Sep 2009
    717
    Mine was behind the sub box, once you've found both ends they just push together and job jobbed
    Oct 2010
    59
    i think ive found it at the 12 o clock position in relation to the sub? surely not a good idea to have washer fluid coming out there!?
    1992 Cavalier SRi 8V RIP
    2002 Mondeo ST TDCi Good riddance!
    2000 A3 8L 17" Ronal TT, -45mm, LCR Splitter, Matt Black Badging, Soon to attempt Lamin-x headlight tints
    Oct 2010
    59
    fluid is bright green? and there seems to be a rather big puddle above the wheel arch! could it be the alarm battery leaking as well? doesnt have the smell of washer fluid
    stu
    Jul 2013
    12
    Just undertaken this fix myself. Mine had come uncoupled in the trunking located in the engine bay. As a footnote for S3 owners - to remove the trunking lid to get at the coupling on the washer pipe you first have to remove the strut brace. This is simply a matter of removing 3 nuts per side on the suspension strut towers. I dried the plastic joint thoroughly and applied bonding solution to the coupling and then wrapped it up in insulation tape to prevent it coming undone again in this location. Thanks to all for the helpful information which aided me in locating the cause of my leak and non-operation of bidet (rear wash wiper)!
