Badger5Monster Motorsport
Results 1 to 15 of 15
    Mar 2006
    lincolnshire
    254
    rear diff (haldex)
    right guys need someone that knows what their talking about when it comes to the haldex system. ive got an 2000 x reg A3 tqs and i have no 4 wheel drive. pluged the vag-com in an got this fault code:
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 02D 900 554 B
    Component and/or Version: HALDEX LSC ECC 0006
    Software Coding:
    Work Shop Code:
    1 Fault Found:
    01155 - Clutch
    04-00 - Mechanical Malfunction
    im guessing this means the haldex coupling is shot and i need a new rear diff right? is there anythin i can check or anythin else that could be at fault? there are no nasty noises or anythin coming from the diff, just what sounds like the abs goin mental when i spin the fronts.
    also this whill be the second diff ive gone through in 4 years!! not good. thanks in advance for your help
    Apr 2009
    kendal
    Have you checked that the precharge pump is working ?
    Mar 2006
    lincolnshire
    254
    bogard how do i check that?
    Mar 2010
    Durham NE
    578
    yea and the connection's to the diff,you can activate the charge pump via vcds
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Mar 2006
    lincolnshire
    254
    vcds is vag com right? i dont have the full version so i wont be able to do it will i?
    Mar 2010
    Durham NE
    578
    yea if you use activation test you can run the pump,stick your head out the window as its not that loud to hear.
    Also as i said check your connections and redo the activation test to see if the pump is working,if all else fails then it does sound like a mechanical failure?
    Do you do the diff and haldex oils?
    James
    Silver Audi 8L S3
    Mar 2010
    Durham NE
    578
    also this might come in handy.
    http://www.kisolutionz.com/ttforum/haldex.pdf
    James
    Silver Audi 8L S3
    Mar 2006
    lincolnshire
    254
    thanks guys didnt think i could the the activation test without a fully registerd version of vag com, ill give it a go tomorro, what noise should i hear? a constant buzzin of an electric motor? or just a quick buzz then stop?
    Mar 2010
    Durham NE
    578
    it should last for as long as you run the test 5-10 sec cant remember mate and yea its a motor you can hear.
    James
    Silver Audi 8L S3
    Mar 2006
    lincolnshire
    254
    sweet ill give it a go. if i was to remove the motor to test it, will i loose all the oil?
    Mar 2010
    Durham NE
    578
    Ive never had one apart but as its a hydraulic pump i would assume so,if you can test the pump and its working but yet you cant operate it via vagcom then its going to be the haldex ecu/control unit.
    James
    Silver Audi 8L S3
    Mar 2006
    lincolnshire
    254
    just tried operating it via vag-com and i cant do it with the un registerd version i have
    Mar 2010
    Durham NE
    578
    bugger,no one close to you that could help you out?
    James
    Silver Audi 8L S3
    Oct 2010
    Hampshire
    294
    Have you checked to see if your earth strap has corroded? Connects the car to either the rear diff or the haldex unit, I cant remember which one it connects to but there are other posts about this being a common cause of failure of the haldex.
    Paul
    Apr 2009
    kendal
    im not 100% sure but i think the pump should run with the ignition on.
