hi all, new to the forum, have got a completly standard 2000 reg s3. iv got an intermittent boost problem, if i drive the car up to temperature and then stop the car for about 10 mins to half hour and then drive it again, the car doesnt boost properly. im sure the turbo is spooling but theres no real boost right through the rev range. it feels like it is holding back, almost like the feeling you get when your clutch is slipping. if i then drive the car on the dual carrige way or long road for any amount of time the problem is then gone again, making me think it is temperature related. iv fitted a new maf after reading they can cause problems, but it didnt sort it. this morning i stripped and cleaned the forge dump valve, and did the test of pressing the piston up, and putting your finger over the top valve. in doing this the piston went straight back down. im pretty sure its not ment to do this, but wasnt sure as havent used these recirculating valves before. can anyone help before i buy a new one, and do you think this could be causing my problem, or a completly seperate issue. sorry for the long post, many thanks
