Mpathe
1st gear
im thinking of doing a brake upgrade and have been looking at mk4 r32 334mm discs and just wondering why they are so dear campared to mk5 r32 345mm discs? anyone know why
£250...what do you get for that? Is that brand new calipers, discs, and pads?
More like used everything!
Nice quotes there mate where did you get them from, i never said "never fading" i said i have yet to see any brake fade but not having been on a track with them they might fade i dont know but its people like you that ruin this forum sometimes i dont know why i f***** bother i really dont, if you dont think the difference will be that big then dont ****** ask other peoples onions if your going to criticise them.Ah ok....so I'm guessing people go for used R32 calipers, then brand new discs and pads. Surely that'll be more than 250 if you go for a decent set of discs and especially pads?
Does the R32 setup really reduce the amount of heat from the brakes being gone after "3 or 4 corners" on standard, to "never fading" on R32 setup...sounds like a bit dramatic, can't imagine the difference is that big???
For r32 setup yes.Does the upgrade involve replacing both the discs and the calipers?
Do you really get that much more stopping power from an extra 2cm of discs...versus a fresh set of discs, ferodo ds2500 pads, and a good break fluid?
Would you even notice any extra stopping power during daily driving? Or do people go down this route to avoid the brakes heating up as quickly on track days where they're getting a constant hammering, so maybe get an extra lap?
EDIT- I forgot to round it off:
In conclusion, a 323mm r32 setup will not objectively outperform an upgraded and maintained 312mm S3 setup, as they will both lock up the wheels on demand, unless you are on a track and have done a *good* few laps and reached the heat capacity of your 312's. Which if you do on the road, you deserve to be behind bars.
So it sounds like a new set of OEM discs up front with some DS2500 pads, along with some racing brake fluid, will give the best bang for buck?
