JMB RetrofitsAH Fabrications
Results 1 to 12 of 12
Thread: my vacuum woes
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    my vacuum woes
    Hi All,
    I swapped my boost gauge over to a brand new one as i dropped my old one on the floor and it had a mind of its own. Anyway now i can see proper reading i realised last night that my vacuum is a bit all over the shop:
    It starts at -20hg as normal
    Then if i put a bit of throttle on idle or moving it goes down to -26hg then after a while it goes to -25hg -26hg bouncing between the two each time i left off the throttle. if i idle after a lil drive it sits at -26hg.
    Does this mean i have a leak somewhere?
    cheers
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    S3BAM's Avatar
    Dec 2009
    Quedgeley Glos
    408
    Most probably i changed all the boost hoses on my old scooby had same prob cable tied them all up cured it.
    What gauge are u running as some cheaper runs seem to flutter a bit my Led one(already on car when i bought it) on my Octy Vrs flutters a little
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    you can put a little reducer in the pipe that stops the fluttering
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    yeh i have the reducer and it does stay steady on the number its reading but it just doesnt sit nicely. i cable tied all the pipes a few months back i should get to see if i missed one anywhere. i think its the pipe off the manifold that has the check valve in between as i have a blue silicone one on instead as my standard one was split. I remember the originalone has a reducing pipe inside the end so its probably not as snug as that. hmm ill have a think and check it out later
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Idle vacuum is less on initial start up as the throttle is held open more on cold start/fast idle until warm... the idle vacuum should increase once past that and will also increase when you let off the throttle as the ECU will close the throttle completely... you will see this for example if you are off the throttle going down a hill...
    <tuffty/>
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    ahh i see but would u say that -26 is still a leak somewhere?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    If you had a vac leak then I would expect the vac figure to be more positive than negative...
    <tuffty/>
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    hmm ok just strange how i can have more vacuum than normal lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    Quote Originally Posted by DaveA3 View Post
    Because by changing the boost gauge you fixed a leak?
    <tuffty/>
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    <tuffty/>
    not that i mean i thought the standard vacuum was -18 to -20 but somehow i have more. guess im just being paranoid
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Is it a cheapish gauge Dave? it may not be calibrated correctly...-26 would mean your rev counter would be showing 6/700 nearly stalling?
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    it was 40 not a cheap one at all really. At full boost it holds at 18psi and sits at 0 when off etc
