Badger5Sky Insurance
Results 1 to 15 of 15
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Sump plug won't budge
    Hmm, had two goes at trying to do an oil change on he S3 but the sump plug won't budge !
    Any idea's of anything I can use to help free it up, how much pressure can I realistically put on this before it snaps or rips my sump apart due to my awesome strengh (i.e - my massive crack bar)
    S3 Paul's Avatar
    Oct 2006
    2,764
    Are you trying to undo the sump plug while the engine is warm?
    It made it easier when i did mine,
    Try penatrating fluid around the nut... but ive never needed it realy
    Noggy Blue 2001 S3
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Yep, got it nice and warm last time I tried.
    I've never needed anything on sump plugs in the past myself, normally quick turn with the ratchet and there loose. I've not done any service work on this car before so its not my doing thats its so tight !
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    as much presure as it takes to either free it or break it, a new sump cost me 38.99 from euro. but as a tip id replace the sump and while you have it off replace the oil pickup pipe as it hasnt had an oil change for a while and maybe slighty blocked.
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    S3KO4's Avatar
    Aug 2009
    London
    850
    First I wish you all the best. But how about you give it a go when the oil temp is high after driving, and use the same bar extended leverage. Make sure you are actually loosening it up not the other way around. It can happen when you are upside down
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    Thanks for the tips, think i'll have another crack at it next weekend I think !
    SamiG's Avatar
    On Boost, ish.
    Southampton, UK
    231
    Get a blow lamp on it dude
    Just make sure you have a spare sump plug when you do it as you don't wana be putting that one back in if it's causing trouble
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Gentle tap with the hammer before turning. Impact normally frees them up.
    Homer Simpson
    Chugger
    North Devon
    2,716
    indeed heat and the use of an impact driver should get it open. Worst case is a new sump which isnt a biggy.
    57 A3 2.0 TDI Sportback (140)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    If all else fails, drop the oil sensor out of the sump to drain the oil for now.
    Thats a big arse sump plug
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Byzan A4 View Post
    Thinking outside the box there dude.... lol. I like it.
    Homer Simpson
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    15 mile drive to get it nice and warm and some WD40 got this out this morning
    Done a full service now except the fuel filter which doesn't want to undo on one side !
    Tackle that tomorrow I think.
    Aug 2009
    Cheltenham
    335
    A slight tap in the tightening (clockwise direction) can often do wonders
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    .... use the sledge.... lol
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by Ian W View Post
    Glad it's out dude.
    Homer Simpson
