Sky InsuranceEM Tuning
Results 1 to 22 of 22
Like Tree1Likes
  • 1 Post By motfree
Thread: What can cause poor mpg ??
    Sep 2010
    wirral
    468
    Just wondering what is causing my car to use soooo much fuel even when I'm driving sensible ..
    Wozski's Avatar
    480
    Alot of factors can make it worse - especially this time of year as its bloody freezing lol - also having a heavy foot, but if your driving sensibly im not sure what else to say....
    Mar 2010
    Durham NE
    575
    seems poor mpg threads is popular this time of year lol
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Wide tyres
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Sep 2010
    wirral
    468
    Coolant temp ??
    CHRIS555's Avatar
    DOPE with added OCD
    Jul 2010
    Midlands
    1,941
    Faulty MAF??
    S3KO4's Avatar
    Aug 2009
    London
    850
    WEIGHT
    WIDER TYRES
    DECAT
    FAULTY SENSORS, MAF, COOLANTS, COIL PACKS..
    FAULTY, THERMOSTAT
    OVERDUE SERVICE
    AIR-CON
    HEAVEY FOOT
    SHORT TRIPS
    BOOSTING and HIGH RPM
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Sep 2010
    wirral
    468
    Brand new Maf on 2 weeks ago ..
    Maybe but it's using around 10 for 30 miles and that's not putting my foot down .. Think I'll go to a garage :-) as I don't have a clue
    S3KO4's Avatar
    Aug 2009
    London
    850
    I get the same, regardless of how carefull I am.
    Just to add to the list. feel free to add your thoughts
    WEIGHT
    WIDER TYRES
    DECAT
    WORN CLUTCH causing slips. not power no go.
    FAULTY, THERMOSTAT
    OVERDUE SERVICE
    AIR-CON
    SEIZING BRAKES.
    WORN OUT BEARINGS
    HEAVEY FOOT
    SHORT TRIPS
    Sep 2010
    wirral
    468
    Actually my coolant sign keeps coming up on my dash ? Maybe that sensor is bust .. But why would this make it use more fuel :-S ??
    m4tty likes this.
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,352
    Blowing exhaust before the O2 sensor leaking more air in with the ECU thinking the engine needs more fuel
    Boost leak and vacuum leak is also the same
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Apr 2009
    Preston
    243
    Quote Originally Posted by motfree View Post
    Im getting this only on very cold morning starts though. Anybody know what this is caused by?
    Strange :S
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    It may be fuelling high as the coolant sensor is telling the ECU that the engine is 'cold' and as a result it is pumping a richer mixture through. I would try changing the sensor first, whilst you are at it, check your tyre pressures and also check the state of the airfilter (infact, check when it was last serviced and when it is next due for servicing).
    EDIT: Coolant sign on the dash also comes up when the expansion tank sender decides that it wants to play up - a new one is about a tenner and should sort it out, oh and its nice and white, and not a light brown colour as they tend to discolour over time so it's easier to make a visual check of how much coolant you have in there.
    Imteyaz.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Quote Originally Posted by djarchive View Post
    Strange :S
    I got this this morning, just scraping snow of the windscreen and the dreaded 3 beeps showing coolant low, went off within 5 seconds....
    Hector8's Avatar
    Aug 2007
    Lisbane, N. Ireland
    55
    Try the simple things first like wheel allignments and tyre pressures all correct.
    Number plate surrounds - Surrounds NI
    Jun 2010
    10
    Tracking to cure poor fuel consumption Classic fella ,also check parcel shelf straps ,could be that too
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Quote Originally Posted by Hector8 View Post
    Quote Originally Posted by Silverfish View Post
    Mr fish, Hector is correct, wheel alignment can cause tyre scrubbing which needs to be overcome by engine power, using more fuel
    Jun 2010
    10
    If you say so ,go get tracking done then and see you in a week when you still have the same problem.
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Tracking can cause higher fuel consumption but i think it would have to be way out though as said by bryzan the engine will be working harder to overcome the resistance caused by this its the same principle as binding brakes and low tire pressures.
    Jun 2010
    10
    Go get it plugged in ffs
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    lol
    Apr 2004
    12,354
    I do say so as it's fact.....
    It is however unlikey that its changed that much without the driver noticing, but it can be a contributing factor if all else has been checked
