Hi, just yesterday on way home from work, my car engine management light popped up and stayed on. I didn't pull over as the car drove fine and was 10 mins away from home anyway. Went out today to test and see if its gone but its still there. I've just done a quick vag scan and the following showed up...
Address 01 -------------------------------------------------------
Controller: 8N0 906 018 J
Component: 1.8L R4/5VT 0004
Coding: 10710
Shop #: WSC 78385
WAUZZZ8LZ1A079589 AUZ7Z0Y1733403
5 Faults Found:
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
17863 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
P1455 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 0000
any ideas guys?
Thanks, Allan.
Coding: 10710
Shop #: WSC 78385
5 Faults Found:
P1296 - 35-00 - -
P1297 - 35-00 - -
any ideas guys?
Thanks, Allan.
