Sky InsuranceAH Fabrications
Results 1 to 29 of 29
    Sep 2010
    wirral
    468
    Ł45 to 155 miles ..
    Had my s3 for about 2 weeks now and I think I've done about 300 miles and it's cost me not far off Ł100
    Over yesterday and today I put Ł45 of fuel in and the light came on after 155 miles - mostly driving about 50 with the odd little blip .. Is this normal or is there something wrong ??
    Also just filled up Ł62 and it's only showing as 3/4 tank my heads baffled it just doesn't seem right
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    More info...
    Is it mapped?
    On average Ł20 the motorway should get you 150 if "sensible"
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,970
    Somethings's wrong, I get nearly 200 miles off Ł30's worth of VPower at around Ł1.25/litre.
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    717
    Ł60 takes me about 375 miles on average, sounds like you have a problem, get it on VAG-COM and see whats amiss
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Sep 2010
    wirral
    468
    Straight through system including decat
    Remap
    That's all I know off .. Mpg calculator was averaging 35 mpg that's what I don't get .. But fuel gauge was playing up the other day going from full tank to 0 then upto half and so on so was told the receiver was goosed but clearly it's actually using that much as Ł63 must fill the tank ??
    No smell of fuel so definatly not a fuel leak
    Sep 2010
    wirral
    468
    You mean get it pluged in on vag com ?
    Mar 2010
    Durham NE
    576
    Quote Originally Posted by sportquattro View Post
    really? what sort of driving do you do? motorway etc..?
    I will average around the doors 80-90 miles to 20 quid!!
    James
    Silver Audi 8L S3
    97 Fireblade fully restored ...just for summer!
    My old Corrado VR6 Turbo... Click me for the build DIY style!
    and many many cars and bikes in the past!!
    Sep 2010
    wirral
    468
    So mine isn't too far off then I guess .. That with you taking it easy ?
    Mar 2010
    Durham NE
    576
    yea steady away,give it beans every now and again,the cold weather has not helped and ive seen the mpg fall,but my s3 has revo stage 2 and all the usual,plus ive got no fault codes,new air mass,n75,plugs etc.....my mate does about similar mpg,but mine on the run can see far better as you would expect.
    James
    Silver Audi 8L S3
    S3KO4's Avatar
    Aug 2009
    London
    850
    Check if you have 4 bar fuel presure regulator, this shows better mpg on the dash but in fact I would say it's up by 8-10mpg. so if you get 36mpg it's more like 26. Decat does not help at all.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Mar 2010
    Durham NE
    576
    this directed at me? im running the stock 3.5 bar regulator as revo specified?
    James
    Silver Audi 8L S3
    S3KO4's Avatar
    Aug 2009
    London
    850
    Quote Originally Posted by AudiS3-Turbo View Post
    Well I would say to anyone who has a 4 bar. the standard one is 3 bars. but that's my little finding with the FPRs I have used.
    Jun 2009
    162
    Yeah this cold weather does make a noticeable difference in mpg, mines dropped to 48mpg! Only just getting 600 miles / tank now, bloody winter. On the plus side you s3 boys must be noticing a nice increase in power with the plentiful cold dense air?
    A3 PD130 TDI Quattro - the discerning mans choice
    (or as I like to think of it the rarer more exclusive S3 derv edition)
    Sep 2009
    717
    James, Thats a daily drive to work of 40 miles each way on the motorway at about 80, mixed in with few local journeys of around 5 miles or so, if out of the way fo the boys in blue and giving it beans it drops but not by much, a banzai trip halfway across Devon and on up to Guildford last August early on a Sunday morning returned 27 mpg and gave 305 miles out of a tankful. I've never ever had less than that from a tankful. Hope you get it sorted.
    Nige
    Mar 2010
    Durham NE
    576
    i can but dream of getting 600 miles to a tank lol
    James
    Silver Audi 8L S3
    Sep 2010
    wirral
    468
    I've filled the tank up to the brim couldn't get anymore in and it's only showing 3/4 tank ?? Maybe it is the sender ?? How much does it cost everyone else to fill an s3 from reserve ?
    S3KO4's Avatar
    Aug 2009
    London
    850
    Ł70
    Sep 2010
    wirral
    468
    Oh I don't know haha have to clean out the sender and go from there .. Fuel pressure regulator under the bonnet ?
    So If a full tank is Ł70 that means I've definatly used Ł45 on 150 miles thought the tank might have been bigger Eg Ł80 so would have been the sender not working properly :-(
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,755
    What size wheel have you got on ??? I know I get approx 30 miles less to a tank of fuel with 235/19. I get 300 to 330 on a full tank to empty.
    red to red black to black blue to bits
    shanejess
    i have a A3 170tdi s-line Black edition remapped by giac to 195bhp, its a company car i do between 490 and 510 miles per tank, my 03 reg S3 does between 310 and 330 miles on a full tank.
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    So running 19's with wide tyres uses more fuel!! Surely not?
    52 plate S3 / Ming Blue / 60K / Celtic Tuning Re-Map, Allegedly 278 Bhp-256 lb/ft (not proven/no chance)
    Sep 2010
    wirral
    468
    What could be up with mine then as my range on the dash is 160 miles and that's full ?? And ive filled it till I can't get no more in and its only showing 3/4 tank :-S !!
    thats me
    Sep 2004
    west yorkshire
    3,755
    sounds like the sender, its under the back seat behind the driver, run the tank down then pull the pump to a angle to remove the circuit board like sender. I cleaned mine up a few weeks ago and its reading fine now.
    thats me
    Sep 2004
    west yorkshire
    3,755
    Quote Originally Posted by LiveWire View Post
    yup would you credit it who would have guessed ........................................
    LiveWire's Avatar
    S3X
    May 2009
    Bristol
    328
    Quote Originally Posted by fingermouse View Post
    Please can you explain how? I am curious :o)
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Typically i've been getting 280 miles to a full tank of V-Power (Ł72+). DIS showed roughly 25mpg.
    Last full tank got me 250 miles - DIS showing 22mpg.
    I do a lot of short journeys, leave it to warm-up and cool-down, commuting in stop/start traffic and it's hilly around here to be fair.
    Still getting it checked/possible replacement thermostat on Monday.
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
  28. #27
    Sep 2010
    wirral
    468
    But If it was the sender it wouldn't use the fuel ... Did 20 ish miles today and the car took Ł10 to fill !!
  29. #28
    thats me
    Sep 2004
    west yorkshire
    3,755
    wider tyre = greater resistance = less mpg
    My brother in law fitted some stupidly wide wheels to a old corsa that killed the mpg totally.
  30. #29
    scoobyra's Avatar
    It's not f@cking ORANGE!!!!!
    Feb 2008
    Portsmouth
    801
    I get 25 miles to a fiver and around 45 miles to a tenner (don't even criticise the maths as I know it doesn't add up lol) round town or on short journeys with my Revo (variable - it'll do what it wants) map in the Red car and about 340 miles to a full tank on the motorway.
    The black car does about 15 miles to a fiver if I'm lucky!
    JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
    BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
    RGV 250N - Bloody fast and loads of fun........I get wet a lot when it rains....
