Plugged My S3 in to Vag Com, and here is what it found:
coyle
From Show... to GO
Stafford
Had my car plugged in to vagcom today to see what it may find as i've only owned it for a week.
here is what I got:
ABS:
01314 - Engine Control Module
79-00
Engine:
16486 - Mass Airflow Sensor too low
P0102- 35- 10
18084- EPC warning lamp
P1676- 35- 10, Intermitant
AWD:
00526- Brake light switch - F
27 - 10, Implausible system
can anyone shed anylight on these? The only light on the dash is the EPS light, it never goes off, I dont know if any of those codes give any idea whats causing that?
the tracking is slightly out, and i've heard that can cause that fault?
any help much appreciated
01314 - Engine Control Module: No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
  • Check Engine Control Module for Fault Codes
Special Notes
  • Engine Control Module stored a Code which influences other Control Modules Functionality.
  • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
16486/P0102/000258 - Mass Air Flow (MAF) (G70): Signal too Low
Possible Symptoms
  • Probably no serious malfunctions
  • Loss of power
Possible Causes
  • Wiring and/or connections (short circuit?)
  • Mass Air Flow (MAF) (G70) defective
Possible Solutions
  • Check wiring and connections
  • Check / Replace Mass Air Flow (MAF) (G70)
Special Notes
  • In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
18084/P1676/005750 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
Possible Causes
  • EPC Warning Lamp (K132) faulty
  • Wiring/Connectors from/to EPC Warning Lamp (K132) faulty
  • Engine Control Module faulty
Possible Solutions
  • Check EPC Warning Lamp (K132)
  • Check Wiring/Connectors from
00526 - Brake Light Switch (F)
00526 - Brake Light Switch (F): Circuit Malfunction
Possible Symptoms
  • MIL (Malfunction Indicator Light)
  • No Brake Lights
Possible Causes
  • Wiring and/or connections faulty between Brake Switch, Brake Lights and/or ABS Controle Module
  • Brake Light Switch (F) damaged
  • Brake Light faulty
  • Fuse(s) faulty
Possible Solutions
  • Replace Brake Light Switch (F)
  • Check / Replace fuses(s)
  • Check / Replace Brake Lights
  • Check Brake Light Switch (F) in ABS Measuring Block
Special Notes
  • FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
thanks for that, but am i right in saying none of these would be to do with my ESP light problem?
Any of these faults can trip the ESP light as they have an effect on how ESP works... I have had the ESP light come on permenantly when my MAF went south... the CEL didn't light up though...
Fix these problems and it will sort itself out (once faults have been cleared of course)
<tuffty/>
yeh, i get what your saying.
just don't realy know where to start, particularly engine control module :(
If you have vagcom at the ready clear the fault codes and see which ones come back. Cant comment on the engine control module or the EPC warning lamp but the mass air flow meter is easy to swap out and the brake light switch isn't expensive to replace if you need a new one.
Cheers.
Is the brake light switch under the pedal?
I dont have vag com, had to take it to be plugged in, and i can't realy keep taking it back to say, could you try it now to see what it says? haha
where would i get a copy for around the £50 mark? theres a few on ebay but don't know which are good and which are crap
