Sky InsuranceEM Tuning
Results 1 to 10 of 10
    Sep 2010
    wirral
    468
    Anyone know size of boost pipe coming off k04 turbo ?
    hi need to know the size of the boost pipe elbow coming off the k04 turbocharger on my s3 as my car is in the garage so cant measure it myself :-(
    i know that the other side is a 2 1/2 " ...
    cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Can I ask why?
    <tuffty/>
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by motfree View Post
    cheers
    Very specific size and shape, and is smaller at the one end than the other.
    If replacing, you either need a genuine one (pricey) or a Forge replacement (also pricey).
    So pricey either way sadly for a small bit of hose. However, it does have to be heat resistant....
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Sep 2010
    wirral
    468
    As mine has a small split in it
    Oh haha always the way never the cheaper parts that need replacing just the expensive :-/ might just see if I can get 1 off eBay just not forge hopefully under 20 then :-D
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    As Welly says you cant put any old silicone pipe on there, it is very special formulation, for the immense heat generated there, and always feels greasy to me..hence the cost
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Forge ones are made from flourosilicone which is oil resistant and heat resistant... normal silicone can be used in some circumstances though, I use a 60mm to 51mm reducer on my GT30 but I still have the K04 heat jacket wrapped around it... on top mount big turbo conversions its a non issue as the silicon is much further away from the manifold heat source...
    If you need a replacement hose then the Forge one is the best option... better and cheaper than the OEM one... its designed to fit properly as its a different angle/shape to the normal 90 deg elbows...
    <tuffty/>
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Agree totally. Also, can be fitted at the road side.... lol
    Homer Simpson
    Sep 2010
    wirral
    468
    Anyone know where to get one from ? Cheapest I've found one for is 65 ... And only comes in terrocota colour :-0
    Cheers for help anyways peeps
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    Forge is the best place mate to be fair.
    Yep, it only comes in 'ocre' I believe they call it. It's a gash colour yes, but that's the way it is....
    OEM ones are similar money for a lesser item.
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    Ebay maybe but thats about the right price... OEM is over 100 IIRC...
    ...And only comes in terrocota colour :-0
    ...same as the OEM
    <tuffty/>
