Results 1 to 15 of 15
    luke2702's Avatar
    Chopper Challenge Champion
    Apr 2010
    Bolton
    446
    Urgent Help Needed
    Hope some one can shed some light here. The Wife has took the car to work this morning and said that the gears seemed a bit stiff (didnt think anymore of it). She has come out tonight and the clutch pedel is stuck on the floor. I have just got the car home by pulling the clutch pedel off the floor and just driving it as normal, is this to do with the cold weather or am i short of fluid some where. If fluid what do i get? Any help much appreciated...
    2002 S3 8L, FORGE 007, R-TECH RE-MAPP, MILTEK CAT BACK NON-RESONATED, JETEX CONE FILTER AND 260 BHP ISH.......
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Is there any leaks anywhere? Is the clutch pedal still to the floor or has it some back up?
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Come back up and drove fine. no signs of any leaks.. Could it be the cold weather??
    beachbuggy's Avatar
    Surrey
    1,727
    the clutch pedal should return back, as there is a big spring attached to it and also the pressure plate in the clutch pushes the fuild back.
    If it's staying down, then yes may be low on fluid or maybe have water in the fluid somewhere which has frozen. But the fluid is topped up from the brake resevoir so if that was low then then light would come on.
    Have a look under the dash to see if the clutch assembly looks normal, Ie nothing broken or hanging off.
    These cars are very common for the little plastic sprogget to brake on the pedal and cause the clutch to stop working. You should be able to tell if that's happened as there will be little bits of white plastic in the foot wheel and you wont be able to engage/disenage the clutch with the pedal
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    no signs of any thing broke and the pedel is engaging and dis engaging fine now. There was a red symbol on which says in the booklet that it is coolant but that has now gone off. Cant see the level of the brake fluid in the chamber, would this be very obvious if it had some in? Thanks for the any further advice...
    G60DAN's Avatar
    Cornwall
    318
    I had this happen for 6 or so miles and it's not happened since. But I would like to know what's going on.
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Quote Originally Posted by G60DAN View Post
    Today????
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Theres another thread with a snapped peddle today....
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,175
    Think I'm going to get mine beefed up before it goes...
    Feb 2007
    enfield
    64
    same thing happened to me about 2 years ago? just pulled the pedel back up and its been fine ever since.
    amd remap,brembo 4 pots,k&n,powerflex mount
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Just been out for about 30 mile drive not a problem its very strange but all now seems good!!!
    G60DAN's Avatar
    Cornwall
    318
    I keep on getting this problem gone out this morning and i can't get any gears wtf.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Happend on my Dads A3 once a few years back.... never did find out what the problem was... pulled the pedal back up and it was fine ever after.... it's certainly not the broken pedal problem as this just goes with a bang and your left with a floppy clutch pedal, bits on the floor and no way of getting gears
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    G60DAN's Avatar
    Cornwall
    318
    I've not got the broken pedal so I'm lost got the Rac on the way 2 have a look as it's free.
    dellboy's Avatar
    Nov 2010
    Switzerland
    43
    my mum kept having this exact problem with her TT 225, replaced the master cylinder and everythings fine again.
