Results 1 to 10 of 10
    From Show... to GO
    Nov 2010
    Stafford
    436
    knocking sound when driving very slow, more noticable backwards..
    hey guys, when pulling off, and moving slowly, i can hear a knocking/clunking sound.
    It's very noticable, but doesn't have any affect on how the car drives etc.
    I checked the drop links and there fine, it seems to be coming from the drivers side, so im thinking cv joint, more likely the inner joint.
    does my diagnosis sound about right?
    If so can I get the inner joint on its own easy enough and is it easy to replace?
    cheers
    Jon
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Question is, is the noise rotary movement related. As in does it speed up when the wheel is turning faster?
    Also, CV Joint failures can normally be located by turning around in a circle on full lock. This will make it easier to hear if a CV joint has failed.
    Yes, inner joints can be purchased singularly, but it's realistically a driveshaft out job to fit it.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Im not saying your problem is not the inner joint but mine has gone twice and both times there was no apparent knocking. I would look into engine mounts or the suspension top mounts imo.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Id say top mount. The reason i say that is, my drivers side makes a clonking/knocking side when at low speeds or over uneven ground at load speeds and my drivers side top mount is shot to ****, just havent got round to replacing it yet lol.
    From Show... to GO
    Nov 2010
    Stafford
    436
    It is movement related,as the wheel does each full turn it makes the noise, but only up to around 5mph,
    Still think top mounts? Or more likely to be cv?
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    CV joint, does it alter if you drive in a circle?
    From Show... to GO
    Nov 2010
    Stafford
    436
    It does it more, or less, so yes it alters on turn,
    another symptom of cv joint failure
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    YEP..
    Aug 2010
    Dumfries, Tartan-land
    203
    Quote Originally Posted by coyle View Post
    hey guys, when pulling off, and moving slowly.....
    Thats a bit graphic for a car forum.
    You should concentrate more on the driving and less on the self gratification.
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Quote Originally Posted by Stanley View Post
