EM TuningChris Nott
Results 1 to 8 of 8
    May 2009
    19
    Rattling noise from front driver side
    Hi Guys,
    I was going around a roundabout, only doing under 10mph as there was traffic in front of me. I went over a pot hole and i heard this loud clunk noise coming from the front driver side. At first I thought i popped the tyre so I pulled over to check and nothing was wrong. However when i drove off and come to some road bumps, i could hear a rattling noise coming front the front driver side. It sounds like a piece of metal is rattling around. It's had no affect on the steering or performance.
    Any ideas? I'm thinking it could be a snapped spring maybe? The car is booked in for Thursday for a check up...
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would say a coil spring or the anti roll bar drop link.
    Both should be easy to spot
    Noggy Blue 2001 S3
    From Show... to GO
    Nov 2010
    Stafford
    436
    mines doing the same, but nearside, going to check everything over tomorrow, my money is on drop links
    S3KO4's Avatar
    Aug 2009
    London
    850
    anti roll bar drop link. two bolts to change. if I was you I would change both sides they are not that expensive. turn the steering all the way to the right it should be obvious to see.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    May 2009
    19
    Thanks guys. Strange thing is that I had the drop links changed last year, both of them. Maybe they've gone again. The car is still in the garage, hopefully it should be ready tomorrow. Will post the problem.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Quote Originally Posted by sanj_c View Post
    please do a lot of posts about similar....my guess drop link-s
    May 2009
    19
    Got the car back a few days ago...It was a snapped coil spring. Had a new VAG fitted, all sorted now :-)
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,062
    Nice one dude, glad you got the car sorted....saw you on the roads recently, the car is looking good!!!
