Chris NottAH Fabrications
Results 1 to 14 of 14
    seen_'s Avatar
    Midlands
    44
    MULTIPLE FAULT CODES! NEED HELP PLZ!
    Hi Guys,
    Need your help!
    My engine management light came on with a couple of codes. So I changed 2 of my ignition coil packs as this is what the codes were around. This fixed the problem for roughly a month but now the engine management light and several codes have come up! The car runs fine, just a slight lack of power can be felt. Just wondering if anybody knows what it could be? Any help or info would be greatly appreciated. Thanks.
    These are the codes:
    17608 Boost pressure control valve
    17705 Connection turbocharger - throttle valve pressure hose
    16500 Engine Coolant Temp.Circ Range/Performance
    16825 EVAP Emission Contr.Sys.Incorrect Purge Flow
    17584 O2 Correction Behind Catalyst,B1 Limit Attained
    16684 Random/Multiple Cylinder Misfire Detected
    16688 Cyl.4 Misfire Detected
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    what suggestions does the Ross tech wiki make in regards to this error
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    17608/P1200/004608 - Ross-Tech Wiki
    17705/P1297/004759 - Ross-Tech Wiki
    ^^ Those two are possibly related
    16500/P0116/000278 - Ross-Tech Wiki
    Thats probably a faulty thermostat
    16825/P0441/001089 - Ross-Tech Wiki
    Not sure?
    17584/P1176/004470 - Ross-Tech Wiki
    Possible boost leak? Maybe related to the earlier codes about the N249?
    TD5 Land Rover Defender build
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    The EVAP system is normally a split pipe. One goes into the TIP, and one comes off the top of the Throttle body.
    Both pipes connect to one of the metal pipes that run along the bulkhead. Check those pipes, and follow them all the way back to the EVAP Canister, found by your header tank.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    S3 Paul's Avatar
    Oct 2006
    2,759
    Have you checked the car before for faults?
    They could be old ones stored on the ecu... i would make note of them... clear each one and then recheck in a few days. no point chasing old faults.
    If the codes come back... you have problems,
    Noggy Blue 2001 S3
    seen_'s Avatar
    Midlands
    44
    thanks guys...atleast thats broken it down to 2 or 3 seperate things that it could be. much appreciated...will pop the bonnet tomorrow and have a look...(Y)
    seen_'s Avatar
    Midlands
    44
    when i replaced the ignition coil packs i cleared the fault codes and check again after a couple of days and no codes came up...but i have recleared them and will definately check again in couple of days...thanks
    seen_'s Avatar
    Midlands
    44
    Reading the ross tech wiki notes another cause for some of the faults may be that I have a dump valve fitted?
    "Stick a V8 in it!"
    14,909
    Are you a chav?
    S3 Paul's Avatar
    Oct 2006
    2,759
    Ignore that post.
    Some people want to hear their turbo ...
    Each to their own,
    However, the Audi ecu isnt happy running a "dump valve" it needs to be something like a forge 007p a recirculating valve.
    i would atleast go back to the standard recirc valve
    Noggy Blue 2001 S3
    Aug 2010
    1,540
    id fit a coolant temp sensor and a set of coils and clear the codes........ and see what codes come back.
    "Stick a V8 in it!"
    14,909
    Quote Originally Posted by S3 Paul View Post
    Ignore that post.
    Each to their own,
    Atmospheric dump valves are chavvy. There really is no arguement there. It serves no purpose other than shouting "look at me, i have a turbo and i feel the need to let EVERYONE know this"
    Fitting a 007p is completely pointless, when the 26 OEM part does exactly the same job.
    I'd be changing the stat before the CTS, as its more likely to be the cause. He can easily find out which it is by viewing the coolant temp on vagcom and watch what its doing. It will no doubt drop when he drives faster, which is pretty typical of a 10 year old worn out thermostat, and will cause the ECU to pop an "implausible signal" code, because the coolant temp shouldnt be going down.
    Welly's Avatar
    Aug 2009
    Gloucestershire
    10,680
    But it's shiny.... lol.
    Each to their own mate, you know this. Atmospheric DV not the way forward though, either a 007P, Bailey DV30, or the OEM item will be the ones to fit.
    OP - Your atmospheric DV will be causing some quite substantial compressor stall - not good for the turbo.
    Homer Simpson
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    standard ones crack every 6 months aswell. i had 2 in the space of 6 months that i bought from stealers on my old a3q
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
Tags for this Thread
