Badger5JMB Retrofits
Results 1 to 21 of 21
    From Show... to GO
    Nov 2010
    Stafford
    436
    A few Issues with my S3
    Hi everyone,
    got myself an s3 last night, it's 2000 /W reg, pre facelift, APY engine on 83000 miles
    A few small issues I want to get sorted asap,
    The fuel gauge, it reads about 25% fuel than is in the tank, as i learned today when it suddenly died.
    The water temp gauge, reads 75-80 degrees, i presume that is the thermostat?
    This morning it took 3 attempts (within 20seconds) to start it, coolant temperature sensor i think?
    The EPS button doesnt do anything, when i press it i think it should come up on the dash? but nothing happens, i have no idea on this one?
    any help appreciated
    Jon
    fingermouse's Avatar
    thats me
    Sep 2004
    west yorkshire
    3,762
    Had to strip the circuit board off the fuel pump in the tank to sort my missreads out its the opening under the back seat the one on the driver seat side , Try to do with a almost empty tank
    Temp reading can be thermostat or temp sender not much to do both
    red to red black to black blue to bits
    From Show... to GO
    Nov 2010
    Stafford
    436
    had it in a local garage today (psi tuning) they said they calibrated the fuel gauge but it was still out, so could be the sender?
    From Show... to GO
    Nov 2010
    Stafford
    436
    Also, ive got a brand new Forge Split R to put on, is this a decent one to fit? or is there better on the same budget? I paid 110 for it.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    split r is fine keep the cap on for recurculating though...
    From Show... to GO
    Nov 2010
    Stafford
    436
    do i need the cap on for it to work as i was under the impression it would be ok running as hybrid, ie without the cap?
    i was also led to believe it should be set up by turning it all the way to the left/anticlockwise and then turning it clockwise 15clicks as my engine is standard apart from that?
    thats me
    Sep 2004
    west yorkshire
    3,762
    there are two retaining lugs at the top and it slides down and off, clean the metal runners and check the fingers that run on them, tricky job but worth it
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    It will work without the cap but it is metered air escaping...
    NoggyS3's Avatar
    Oct 2010
    Southampton
    242
    Quote Originally Posted by coyle View Post
    Behind the steering wheel, below the instrument cluster there is a small plastic cover. Little tug and it will pop off. Behind the cover are two screws, remove these.
    You should now be able to pull the instrument cluster from the dash, remove all wires from rear of IC and with the wheel centerd you will be able to pull it out from behind the wheel.
    Remove all screws from rear off IC and it will pull apart. Lift the clocks and i put money on that there will be black tape covering the ESP light.
    Reverse process to refit and check if the ESP lights up when switched off!
    Wanted : Stainless Cat-Back monies waiting
    Standard Nogaro Blue 21O AMK S3
    From Show... to GO
    Nov 2010
    Stafford
    436
    would a 007p be a better option then?
    From Show... to GO
    Nov 2010
    Stafford
    436
    Quote Originally Posted by NoggyS3 View Post
    why would there be black tape over the light? would someone cover it for a reason?
    il check at the weekend.
    also because its not using the standard headunit, the top part of the IC display isn't being illuminated, (it comes on to say OK when i turn the ignition, so i know it works) but are there any other messages etc that would come up on there that id be missing? eg low fuel etc?
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    although a car shouldnt fail an MOT with the ESP light on rather than fixing the problem the owner has just taped over the light. the esp doesnt come on in the display but in the clocks. low screen wash and others do!
    Go with the 007p rather than the split r unless you have Chav tattoo'd on yourself some where!
    Temp reading start with temp sendor/sensor first
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    From Show... to GO
    Nov 2010
    Stafford
    436
    Quote Originally Posted by Speedy Steve View Post
    so do you think the esp light is constantly on then? because obviously i dont know if its being turned on or off with the button.
    temp reading.. its hitting 80* so it looks like its working, as oppose to it not working at all and staying all the way to the left if you follow what im trying to say, thats why i put it down to thermostat, as from searching the forum it seemed to be a common problem which is solved by replacing the stat.
    i know split r gives a dumping sound, but im more inerested in the better DV rather than just the sound. I paid 111 for it yesterday, i could always try to take it back and get a 007p but i was advised if set up properly the split r is the better DV, but with some reading on the forum it seems thats not the case
    NoggyS3's Avatar
    Oct 2010
    Southampton
    242
    Yes mate it is known to be done if there is a problem with the ESP that people tape it off! You will know straight away if its been open before because there is a sticker seal over the join line on the back of the IC! If its torn or not there then its been tamperd with.
    As for the top of the LCD display, doubt it will work with aftermarket HU but should display warnings like
    Low Washer Fluid
    Low Brake Pads
    Low Fuel
    Bulb Failure etc...
    Alex C's Avatar
    Lizard, Cornwall
    2,602
    I think the s3 fuel tank has two separate low points due to the prop shaft tunnel running under the centre of the car, so when the fuel level drops you efectively have two fuel reservoirs in your tank. The fuel pump is on one side of the tank. In order to get the fuel on the isolated side of the tank to the side with the fuel pump there is a secondary pump. If this secondary pump has failed then could this cause your fuel gauge to tell you that you still have 1/4 tank of fuel but your fuel pump cant pick it up??
    ...may be wrong
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    mk1chopper's Avatar
    Missing the S3
    Oct 2006
    Bedford
    1,095
    The top of the dis will display the radio settings, as you've got an aftermarket head unit it wont display anything. The top will also display warning symbols too, with the engine running if you press in the left hand side clock adjuster on the IC it will perform a system check and flash up all the symbols. If your fuel sender worked properly you would have a low fuel symbol displayed when your close to empty.
    if your ESP light has been taped over and is staying on it can sometimes be the cars alignment being out.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    ESP - Floor it in the wet from a standing start. Then press the ESP button and do it again. When it's on there'll be a sudden loss of power (like turning a swich off!) before traction is regained (apparently). At least then you'll know when it's on/off.
    Temp gauge - I'd say thermostat. Got the same problem and my temp sender has been done already. It's on the list of things to do once I've finished painting the lounge/stairs/landing...
    Aug 2010
    bradford
    1,252
    iv got a split r on mine with a newspeed filter and it sounds great and dumps nice 2
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    From Show... to GO
    Nov 2010
    Stafford
    436
    Im looking at getting a jetex filter, they seem well thought of
    KB
    KB's Avatar
    Jul 2010
    Inverurie, Aberdeenshire, United Kingdom
    195
    ive got a 99 apy without esp, just a rather vacant looking switch blank instead of the esp switch! someone hasnt put a esp switch in to replace the blank have they? pop the switch and see if there is wires attached to it
    From Show... to GO
    Nov 2010
    Stafford
    436
    I will do, but if that was the case why would the esp light always be lit on the cluster?
