Steering Assist in VAGCOM
metricspaces
NULL
Anyone ever try adjusting steering assist in VAGCOM? Here's one guide:
Steering Assist
You can change how much input is needed on the wheel to turn it. It's set at 5 on the GLI.
Select 44 (Steering Assist)
--> 10 Adaptation
Read channel 1.
Lower numbers are harder steering, higher numbers are easier. Range is reported to be between 0 and 6.
And some links...
power steering one no as the 8L runs a belt driven pump so not adjustable, you can adjust certain things but not as many as newer models
6
578
686
7
