Heater display lighting
dougie175
NULL
My heater display lighting has gone, I have pulled out the centre knob which reveals a bulb.
If this the only bulbs that illuminates all 3 knobs?
Also do you remove the bulb from there carefully, or is it a case of having to take the controls out and remove the bulb from behind?
Im not sure how you change the bulbs as by the sounds of it you have dial controls i have the digital on mine its a long shot but have you checked the fuses there might be one for this. It seems strange for all the bulbs to go at once it could be a bad connection also.
The display hasn't lit up since I bought the car recently, so not sure if it all went out together or not.
Ill take a look at connections and fuses and report back
No 1 had this problem and had to replace the bulb to get the lights working for their heater display?
I
685
imported_2219
I
I
imported_AudiAuto
I
10
