Badger5Chris Nott
    Aug 2003
    North West
    118
    Load Mats and Washer Jets adjustment?
    Couple of quick q's,
    Did the A3/S3 ever have an official boot load liner/boot mat available as an accessory?....maybe someone with an old audi A3 accessories could confirm? If so what price/part no?...my boot carpet needs some protection!
    One of my windscreen washer jets is firing too low and not properly getting on to the screen. What is the correct way to adjust these?...I know they're heated but i presume you just manually take some pliers to them and change there angle...is this correct? (Maybe one for HTC)I don't want to do anything too manual to them in case of breakage...unless that is the right way to do it!
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Aug 2003
    Surrey
    469
    Re: Load Mats and Washer Jets adjustment?
    Check vagparts.com for load liners or luggage nets.
    I think A3 one is 27 pounds or so.
    And I think there is an official tool to adjust wiper jets. If it has only been doing it recently then I would guess it has some grit in it - you may find cleaning it with a pin solves the job.
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    I've always used a pin to adjust them, there must be a more accurate way...... i done it once and will never do it again !!!!!! [img]/ubbthreads/images/graemlins/crazy.gif[/img]
