    Nov 2010
    141
    Is there an upgrade like this for the A3?
    Hope no one minds me posting a link to this as a reference, but this is supposed to be a very good upgrade for the 1.9tdi. Finally fitted R32 DSG airbox feed to my uk R32 - uk-mkivs
    I have a 130PD A3, just wondering if there is a way of replicating similar for an audi equivalent?
    Nov 2010
    141
    No one got any ideas on this one?
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    There must be some induction kits that have uprated air feeds, or at least models within the range that have larger OEM pipes (like he found out in the link). I'd guess the S3 has the biggest, but probably won't be a straight swap onto a diesel engine, and you've already got the best diesel (I think) so probably have the best OEM piece you can use. I'd look at other 1.9TDis on the same chassis that came with more power - some mk4 Golfs had 150bhp, that's probably going to be the best option.
    This is all purely speculative, I don't have a clue if you'll have any luck, but that would be my best guess at a first step - find out if the airbox feed on a 150bhp Golf is a larger diameter than your own. The 150s had all red "TDi", by the way, and were only 2000-2003.
    Good luck
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jul 2010
    bristol
    647
    your better off just running a 4" cold air duct from the front bumper to be honest, it wont look OEM but will definately work far better than anything standard
    Nov 2010
    141
    Its more the OEM look Im going for.
    None of the other feeds for other chassis will fit unfortunately as the A3 feed goes much further into the wing, the 150s only have a restrictive pipe also as they all do the same upgrade and shown on the topic I posted.
    Nov 2010
    27
    you can run a cold air feed from your front bumper and use a hole cutter on your airbox and connect the other end upto that if you fit it with a K&N panel filter aswell it works alot better than a induction kit :P
