Monster MotorsportEM Tuning
Results 1 to 27 of 27
    Matt_Turbo's Avatar
    Nov 2010
    19
    A3 1.8T Revo Mapped...Not fully boosting
    My 1998 S plate A3 1.8t has been mapped for about 18 months now. When my mate had it done it was great, pulled hard. But over the past 18 months he hasn't hardly driven it hard maybe once in a while. Anyway I bought it from him yesterday afternoon and it's only running 7-8 psi so pretty much standard. Anyone ever experienced this before?
    Regards,
    Matt.
    1998 S plate Ming Blue A3 1.8T: Mapped, Forge 007p, Coilovers, 17" RS4 Replicas
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    The best thing to do would be a vag com scan to see if anything comes up on there. Theres a lot that can cause your symptoms if the cars not running right it wont boost properly. You could also check the dv and look for any obvious boost leaks as well.
    Matt_Turbo's Avatar
    Nov 2010
    19
    Just scanned if using a sealey vag scanner. I got codes 00561 and 16514. I do have a rough, hunting idle at times. Today i replaced the blue coolant temp sensor to get the gauge working. Getting really annoyed with it now
    Chugger
    North Devon
    2,716
    57 A3 2.0 TDI Sportback (140)
    Chugger
    North Devon
    2,716
    obviously faulty lambda. has it been decatted or anything? The 2 faults are probably related
    Also you are probably only getting 8psi because of the misture deviation throwing it into limp or softlimp mode
    Matt_Turbo's Avatar
    Nov 2010
    19
    Standard exhaust system no decat or anything. It doesn't go into limp mode as it still revs all the way round just feels like its on a standard map.
    Chugger
    North Devon
    2,716
    well its restricting boost of some reason... and your fault indicates lambda
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    The 00561 code is a vac/boost leak iv had this come up many times in fact its coming up again on mine due to a leak between my throttle body and inlet manifold its a pain in the arse as you will have to go over all the vac lines and boost pipes to check for splits this would give you a rough idle as well. The lambda code could be thrown due to this but i wouldnt rule out a new lambda sensor yet but replace whatever pipes are split first and see if it comes up again.
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    A symptom of this code is reduced boost pressure by the way.
    Aug 2010
    Dumfries, Tartan-land
    203
    MAF?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    A bad maf has thrown this code on mine before but i would sort out the vac lines first as they are cheaper if yours is an agu the mafs are over 100 even with an exchange basically start with the cheaper things first for obvious reasons. The most common are the pipes which are connected to the inlet manifold but tbh if they havnt been changed id do them anyway as the splits are not always obvious.
    Matt_Turbo's Avatar
    Nov 2010
    19
    Checked all vac lines, all boost pipes and no splits or leaks. I need to pressure test the system really to check the intercooler as I've had a split intercooler before. Will also try unplugging the maf and driving it later see if the running changes at all
    Chugger
    North Devon
    2,716
    lol dude its showing up a blatent fault with the lambda, either a short or open circuit. This definately should be your first port of call
    Matt_Turbo's Avatar
    Nov 2010
    19
    My guess would be something is upsetting the afr which is why the lambda code is coming up as it's seeing a difference in normal values. So i think i need to find out exactly what's going on with the live datafeed from vagcom?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    As there are no boost/vac leaks the only things i can think of are the temp sensor , maf , iat sensor and maybe a clogged air filter i wouldnt rule out the lambda but as you know if the af ratio is way out it will log a lambda fault. This should help you out a bit but its hard trying to diagnose a problem from a computer screen lol.
    Matt_Turbo's Avatar
    Nov 2010
    19
    I understand lol. A friend who recently sold his cable throttle golf 1.8t has his mapped and reckoned that only ran 6-8psi. Im sure it should run just over a bar one stage1?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    I cant comment on boost pressure as i dont have a boost gauge something else i havnt got round to doing lol but i think its down to the map for how much boost there is but im not 100% im sure someone who knows more can verify this.
    Matt_Turbo's Avatar
    Nov 2010
    19
    Just read your actuator thread. Going to check mine later never thought of it coming loose, however i did think of turning it up slightly yesterday
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    You could take a look at it but it doesnt explain the fault codes though when mine was slack it would build up boost and at about 3k rpm when it normally picked up more instead it was as flat as a witches tit and i was getting no codes.
    Matt_Turbo's Avatar
    Nov 2010
    19
    The free things are always worth checking first. If it helps then i shall replace the lambda sensor as well. Will also check the maf tonight
    Matt_Turbo's Avatar
    Nov 2010
    19
    Just ran the car with no maf and it idled perfect. Ran with no boost so i think that's where my problem lies!
    Matt_Turbo's Avatar
    Nov 2010
    19
    Ok little update.
    Bought a new MAF today and pulls alot harder. The 007p valve is still very quiet with the drilled box though which I find interesting, as I'm sure with a drilled box the recirc valve is normally quite loud still?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    It looks like you have sorted it has the lambda code gone aswell? As for your dv you can turn it around and its supposed to make it louder you swap the end in the tip to go to the turbo and vice versa and your vac line will be on the side instead of the top if you understand me lol. I was going to do it today on mine but my driveshafts f****d up sorry for the technical term lol.
    Matt_Turbo's Avatar
    Nov 2010
    19
    Haha i will give that a go tomorrow! Not had my ecu scanned again yet, but i guess the codes will still be there as i drove the car last night and today. It feels so good to have boost back, can't wait to route the boost gauge hose better so the door doesn't crush it anymore. I still can't believe how different it is it feels like a completely different car. I still have a rough idle though hunting etc think its overdue a service to be honest
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Clean your throttle body as well makes a big difference if its full of crap it causes a bad idle.
    Matt_Turbo's Avatar
    Nov 2010
    19
    Ill give that a go on Saturday :-) Im loving my car now
  28. #27
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    Quote Originally Posted by Matt_Turbo View Post
    yeh mine boosts at 16ish psi r-tech stage 1
    also if you turn it around it makes a high pitched ping noise aswell lol i werent a fan so left mine but my induction gives a good noise anyway.
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
