SiGainey
Anyone done it, my local Audi specialist says it can't be done which is gutting! Anyone know if it's possible and I am being told porkies?
You rock!!!!!!!!! Got any part numbers I can quote at them? Was it just a case of steering wheel off, new stalk in, wheel back on, VAGCOM coding?
Cheers fella, much appreciated Wanted the part numbers so I could tell them to order those parts and fit em as others knew it worked
Excellent. I need to persuade them that it's possible as they say it's not. Any help appreciated
This has been done to death so have a search about... best mod I have done...
Get the kit from here...
Audi TT A3 1.8T - Retrofit Cruise Control Kit on eBay (end time 29-Nov-10 19:00:00 GMT)
<tuffty/>
the manual is for a VW... the only difference is the engine code which doesn't make too much difference as long as its close to the same year as yours... I bought the same kit and fitted it to mine which is an AMK...
Can't remember the correct engine code in the manual you need to get the right wires connected to the ECU but as I said this has been done to death and there are plenty of threads on this very subject with all the info you need...
You will also need access to VAGCOM/VCDS to enable the cruise control in the ECU or a dealer should be able to do it...
<tuffty/>
I listed the part numbers in a previous thread.... Audi will tell you they aren't listed... you won't get the bits any cheaper than from Tee Side tbh...
<tuffty/>
Not gonna get it cheaper parts wise than from tee side and its 3 hours labour of anyones money... Awesome did it that cheap to people through the door...
<tuffty/>
So... the same kit as the link I posted 4 days ago... you are welcome by the way :thumbsup:
<tuffty/>
