JMB RetrofitsSky Insurance
Results 1 to 19 of 19
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    S3 Lower door fins / side strips
    My drivers side door fin (the grey rubbery looking bit) is totally out of line with the rear piece. I have taken it off to investigate & seems the steel inside them rusts over time therefore deforming the mounting of it & not sitting flush. Does any one have an idea of cost or part number ? I also understand these come pre primed & require painting ?
    Any help would be great.
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,196
    Have a search on the forum. Cost is astronomical (about 130 I recall) and they come painted I believe. JoJo posted a repair guide some time ago but it's not a permanent fix unfortunately. My nearside door strip is starting to go the same way. Hopefully I can get it off & repair it before it gets too bad.
    Sep 2009
    Isle of wight
    207
    Yeh that's about right bought one from audi last year
    Chugger
    North Devon
    2,716
    Yeah they are about that. But they come primed not painted, atleast the one I bought wasn't.
    57 A3 2.0 TDI Sportback (140)
    sean_s3's Avatar
    May 2009
    West Yorkshire
    264
    If your happy to use eBay email someone who is breaking an S3 as i was offered a full set for 50 , which is much cheaper than at the main dealer. If they are in good used condition the colour will probably not be far off from your original ones.
    Cheers.
    S3 Big Turbo
    Sep 2010
    207
    I've got the s3 door fins for sale if your interested drop me a pm, we can sort something out?
    There in high build primer atm
    Jordan
    Apr 2010
    41
    I fixed them for 10
    I had the same issue.
    First thing I'd point out is. Make sure you use a magnetic screwdriver to remove the screws which hold strip on from the inside. 3 screw are hidden with a rubber plug. If you loose the screw you'll have a nightmare to get it back. m4 machine screw is what you need to replace. I left the old screw in the door channel.
    I then bought Sikaflex 521 which is used to bond body kits to cars etc. I then glued the nylon runner back into the rubber door strip using some J clamps from B&Q. Cheapest fix I reckon.
    Let me know if you need more info?
    Nov 2005
    UK
    1,688
    I ve already had it apart & the nylon runner is fine is just being out of the fin casue of the rusted reinforcement rod. I dont really wanna bond anything cause that means it aint coming off, i have read that these areas are prone to rust (the doors).
    wanted for 8L S3:
    Milltek system
    Apr 2010
    41
    No. You got me wrong. You don't bond it to the door. You bond the nylon runner back to the trim piece. Effectively removing the need for the reinforcement rod as the 2 bit are bonded together.
    Nov 2005
    UK
    1,688
    oh i see will need to take a closer look at them see how easy it is to get them rods out.
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,688
    does anyone have part numbers for this ?
    wanted for 8L S3:
    Milltek system
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,196
    Quote Originally Posted by northern monkey View Post
    Got any pics? If I understand you right, what you're saying it to take the fin off the door, remove the nylon runner and metal reinforcing rod, and then bond the nylon runner back into the plastic trim again. Once done, screw it back onto the door. Right?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Quote Originally Posted by The Doctor View Post
    Don't know what metal reinforcing rod you are talking about, but in the pics below is a knackered and a brand spanking new side skirt/lower door fin. I guess it's possible to to remove the nylon runner with the brass inset bolts intact complete, then pull the rubber part out and refit the nylon runner with silicon as the filler/substitute for the rubber part. I highly recommend you go back to Audi and purchase the correct screws before refitting. They are 18p each, and you need 4 per side. The reason being, the original bolts - on my car at least - have iron content, and will rust away, aswell as being magnetic to some screwdrivers. The new screws I got are galvanized and don't magnetize, so you need a stead hand to feed them through the holes when refitting.
    As for dropping the screws dropping into the door channel, just remove the doorcard(5 minute job once you know how), and you can get to them with a pair of long nose pliers.
    Nov 2005
    UK
    1,688
    the reason it has turned that colour is becuase of the steel reinforcing rod behind the nylon runner rusting over time. These cars are atleast 7 years old now (not suprising really)
    wanted for 8L S3:
    Milltek system
    Apr 2010
    41
    Yip. That's correct. Sorry I was a little vague.
    Apr 2010
    41
    Quote Originally Posted by jojo View Post
    Can you explain the quick 5 minute job to get the door card off for me? Sorry for being dense!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    2 screws on top of the door car at either end, one screw in the door handle, the bit where your fingers go through when you grab it. Remove the door handle trim, it's the part where your fingers go through again, and remove two more larger screws once that part of the trim is off. Now the whole door card pulls upwards and straight off! There is wires and connectors between the actual door and the door card, but you don't need to disturb these to get to the door channels unless you have fat hands.
    Apr 2010
    41
    Just wanted to thank jojo for the door card removal tips. You saved me time and an ear bending from the wife. I would've been there hours trying to find the last 2 screws under the handle trim piece. And I now have the correct screws and there isn't a rattling screw coming from inside the door. So good all round.
    G
    a31.6sport's Avatar
    Mar 2012
    A, A
    7
    Unhappy A3 sport
    Just wanted to thank jojo for the door card removal tips. You saved me time and an ear bending from the wife. I would've been there hours trying to find the last 2 screws under the handle trim piece. And I now have the correct screws and there isn't a rattling screw coming from inside the door. So good all round.G
    Can someone tell me how to remove the small strip on the bottom of the wing mine is a sport model there is only half the rubber there showing hole whee the bolt goes but what else is keeping it on Thanks in advance
