JMB RetrofitsBadger5
Results 1 to 29 of 29
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Thermostat or temp sender?
    Hi guys, recently my temp gauge is only reaching 80 degrees and it takes a good 10mins from cold to get there. This has started happening over the past couple of months I guess. Before, it would sit bang on 90 degrees as I would expect. I had the temp sender replaced about 15 months ago which was triggered by a warning on the dash if I remember correctly (I now have the green one) but I'm not sure if this would be the cause of my new problem or maybe it could be the thermostat? Anyone shed some light on this please. Either way I'll probably fix it myself, just want to make sure I'm replacing the correct bit! Thanks.
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    green temp sender if updated part
    your issue is the thermostat
    get a genuine one from Audi + o-ring and g12 plus
    Thermostat replacement procedure..>> - AudiWorld Forums
    BASS 666's Avatar
    BMW aye right dead on..
    Sep 2010
    belfast
    463
    i had the same problem and i changed my stat yesterday job done..
    2002 1.9 tdi 130ish brake a4. full reiger body kit, 19 inch rs6 avant rims, eibach springs, home made grill, full leather interior, centre arm rest, quad powerflow exausts, a few engine mods, chrome door mirrors, aero wipers, s line door blades.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Nice one lads. Thanks. Got a part number & price?
    NoggyS3's Avatar
    Oct 2010
    Southampton
    242
    I would also say its the stat. My S3 did same thing, changed stat and hey presto all sorted
    Stat and O-ring is around 4
    Not sure on the G12 as a mate gave me a bottle.
    You may as well get a new dipstick funnel as i can guarantee it will disintegrate as soon as you touch it. They get very brittle over time.
    Part No. 06A 103 663 B 3.50 or there abouts.
    Wanted : Stainless Cat-Back monies waiting
    Standard Nogaro Blue 21O AMK S3
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    355
    sorry to be an idiot but what's the stat?
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    thermostat..
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    I had similar issues which were fixed by changing the temp sender. Easy job just make sure the engine is cool before you remove it otherwise your get covered in boiling hot coolant like myself :/
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,915
    Temp sensor oh yes oops
    BASS 666's Avatar
    Sep 2010
    belfast
    463
    did you delete my last mesg ?
    Oct 2010
    Hampshire
    294
    Its a good idea to disconnect the battery as the thermostat is right behind the live connection on the alternator, coming from the battery. Else cover the connection. Audi specialist Abtech fried mine.
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Quote Originally Posted by pj123 View Post
    I'll second this as i fried mine when i did my thermostat
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Already replaced the diptsick tube last week when I did the PCV simplification/catch can mod. And yes, the old one snapped as I expected it to! Forunately I prevented any bits from dropping into the sump.
    Good advice re battery disconnection. Presumably I only need to disconnect one terminal? Only problem is I don't think I have the radio code. Any way I can find this out before disconnecting the battery?
    Oct 2010
    Hampshire
    294
    yes just one terminal, you should always disconnect the negative from a battery first (and its always the last to go back on). Covering the alternator terminal could be your other option, plus being extra careful!
    Paul
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    -ve terminal is what I thought, given the -ve earth.
    Anyone got a thermostat part number please?
    luke2702's Avatar
    Chopper Challenge Champion
    Apr 2010
    Bolton
    446
    Part no from GSF is 931vg0450. 11.46 including vat...
    2002 S3 8L, FORGE 007, R-TECH RE-MAPP, MILTEK CAT BACK NON-RESONATED, JETEX CONE FILTER AND 260 BHP ISH.......
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Love this forum! Thanks guys.
    117
    I will be attempting to replace my stat soon, after having the exact same symptoms. I bought the following last night from Audi:
    Thermostat - 24
    Rubber O-ring - 3
    1L G12 coolant - 7.
    These are approximate prices (give or take 1), and include VAT.
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Just checked. Seems to be a different part number now?
    176VG0110THERMOSTAT A3 Petrol 9/96 >
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    As above, number 6 for APY, AMK & BAM
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    22.84
    luke2702's Avatar
    Apr 2010
    Bolton
    446
    Quote Originally Posted by The Doctor View Post
    Only got mine last week. So dont understand...
    From Show... to GO
    Nov 2010
    Stafford
    436
    going to do my stat this week, is one like this ok? Audi - Euro Car Parts UK
    or would it have to be genuine audi?
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    The one from euro should be fine but they wont be much more if any from the dealers so it might be worthwhile getting one from them.
    From Show... to GO
    Nov 2010
    Stafford
    436
    I heard they were 24 from the dealers.. which is triple the price, if thats true i'll go non gen, if dealer is close to the 8.99 il get oem
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Just go with a good brand.
    I got mine from AllGermanParts, was just over a tenner iirc.
    A nice rule of thumb is to look at the stat itself, if the manufacturer has bothered to put their name on it, its probably reasonable quality.
    TD5 Land Rover Defender build
  28. #27
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    It was something like 18 quid when I went to get one last week from the dealer, so I went to a local factor and got one for 4 quid inc VAT. The best tip I can give you for replacing it is to certainly remove the battery negative and also remove the supply lead from the alternator, then you can get a 5mm allen key socket UNDER the thermostat housing and it makes the job a real easy one - took me half an hour including changing the coolant for new G12 stuff
  29. #28
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    I too got one for 5 from a local motor factor which lasted 2 months so i got another one for 5 from a different motor factor which lasted less than 2 months so i got one from gsf for 13 and its been fine for 6 months maybe i was unlucky but its something to think about.
  30. #29
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    TPS or Audi
