S3 seems to run bad once warm ! And won't start ??
motfree
wirral
Had a few problems with my s3
Anyways replaced mass airflow and cam shaft sensor but now it seems to be cutting out once warm then will not start again .. Last time came up with the above faults but these have been replaced .. But before I put the new turbo on the car wouldn't hesitate to start ( didn't have boost mind ) .. My mates don't have a clue neither do I and I'm loosing patience haha any help would be great :)
Ps live in north west ;-)
knock sensor just below the oil filter...vag first but thats what my monies on
Possibly the fuel pump i take it there are no fault codes ? Or as above lol.
Knock sensor was on the diagnostics no1 and no2 I think !! What do these do ?
its a snensor that fits in the block, only way is to replace....otherwise the situation will get worse
make sure you get a car specifc one too as i got sent a golf one and it didnt work!! £40 wasted
Is there 2 sensors ? Might just take it the garage and let them sort it out .. If it makes it haha ..
nope just one..... and its a royal pain in the *** without a ramp....you have to remove the undertray and the mount at the front of the inlet manifold, undo the securing nut from the top then remove the sensor out the bottom, **** of a job
25
8K
6
17
