Chris NottAH Fabrications
    Jun 2007
    614
    Fitting Wing Mirror Caps
    Anyone got any info on fitting wing mirror caps to a pre-facelift S3? How do I remove the old ones?
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    The OEM ones aren't caps, they're housings. If you bought caps then they just stick on with double sided tape.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    Quote Originally Posted by metricspaces View Post
    Adjust the wing mirror glass as inwards as possible, then use your fingers to pull the glass off it's base with the gap, need to be a bit gentle, or it will crack! Then you need to undo the 2 wires that power the demister, you can just pull these off with your fingers or use a small flat blade screwdriver. Now there are 3 small crosshead screw(torque screws with a different thread if you have alloy mirrors), undo these and the whole cap pulls off upwards.
    Fitting is obviously the reverse of the above.
    You've got to have a laugh!
    Jun 2007
    614
    Thanks. I've gotten the housings, not caps. The ones I got are like these here 88-Tuning Shop - Alu-Matt-Look Spiegel (Spiegelgehuse) passend fr Audi A3 8L Bj. 01-02 mit normalem Beifahrerspiegel Alu-Matt-Look Spiegel (Spiegelgehuse) MC08147.1 , but apparently fit a pre-facelift, so we shall see
    I don't understand this bit about
    "Now there are 3 small crosshead screw(torque screws with a different thread if you have alloy mirrors"
    Can I unscrew these with a normal Philips screwdriver? Or will I need a special head\screwdriver to remove them?
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,889
    If you have the standard body coloured caps, then a philips screwdriver will do the trick, if you have the alloy ones, then you need a torx screw head(I think).
    Jun 2007
    614
    Quote Originally Posted by jojo View Post
    Ah right, makes sense now, thanks! I've standard caps, so should be good with the philips.
