Badger5Sky Insurance
Thread: Steering noise
    Sep 2005
    Derbyshire
    180
    Steering noise
    Hi People of ASN,
    2 things may be related but doubtful.
    When steering right I get a strange metallic almost graunching noise, this generally happens at 15-25ish MPH on roundabouts or when turning into a parking spot. It appears to be coming from the drivers side of the car / front middle of the car.
    Also when selecting reverse and raising the clutch I get another metallic / binding noise for half a second or so.
    Brakes dont appear to be binding as no noise from them whilst driving etc.
    Car is a 1999 S3 APY.
    Any ideas / things to look for?
    S3KO4's Avatar
    Aug 2009
    London
    850
    I would say your drive belt could be the cause. obvious one would be checking the fluid level. but the drive belt on the power steering pump could have an effect if its too old! hope this helps. check for crack on it.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
