Chris NottMonster Motorsport
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    corrosion above number plate
    hello. i have a patch of corrosion on the small plate above the number plate. the one that covers the number plate lights, it would probably be easer and cheaper to replace this plate rather than re-spray it. how is it removed, do i have to remove the trim on the inside of the boot lid or can it be accessed form the outside. any tips before i start out would be much appreciated. thanks
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    yes, remove the screw in the handle of the plastic trim on the inside of the car/boot lid, then pull the plastic trim off, its secured by some strong metal clips...so pulling is your only option, you will need to be forceful
    Once off you need to disconnect the 4 small plugs going into the number plate lights and boot releases, theres two 10mm nuts to undo....then two small clips to push in at the outer endge of the trim (from the inside), it will then release
    just dont do what i did and close the boot whilst its off
    the primed ones cost around 70 off Stoke Audi (off here) - i have my old one lying about that im going to advertising soon if you feel you want to sit there rubbing it down instead of shelling out
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by 1animal1 View Post
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    JD09's Avatar
    Dec 2009
    Cheshire, Alderley Edge
    3,078
    I had this on mine. Audi quoted 246ish quid to supply a new part and fix it.
    I said f off and they came down to 82 to just respray it. Been fine (touch wood) ever since!
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    you have to jump in the boot and connect the bloody thing back up
    cg
    cg's Avatar
    Feb 2007
    shropshire
    44
    thanks, job for the weekend i think.
