Chris NottAH Fabrications
Results 1 to 14 of 14
    One
    Nov 2004
    12
    Four wheel drive Ratio?
    whats the ratio for rear vs front power provided on S3?????
    is it 50-50???
    or is it more towards the front like 40-60 ????
    pazaz's Avatar
    May 2004
    S.Wales
    316
    Re: Four wheel drive Ratio?
    They are two wheel drive until the fronts start to slip and then it instantaniously tansmits power to the rears as is required to eliminate any wheel spin.
    Mar 2004
    238
    There was a discussion about it some time ago so do a search, also have a look at this link
    http://www.haldex-traction.com/default.htm
    Nov 2004
    Bristol
    Wow. If I drive up from Bristol to London and back on the motorway with some fun along the way, I can average 33mpg or once even 35mpg.
    May 2004
    Billericay, UK
    278
    In previous posts it was suggested that pulling the Haldex fuse made the car FWD - pulling the Handbrake up a notch also had the same effect.
    Greg
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    I think the maximum split is 50:50... This is because the rear wheels are the only ones that are disengaged. if it were to splot 99:1/1:99, it would need to be able to cut power to the front wheels too, which it cant.
    Rich
    Mar 2004
    238
    I suppose the easiest way to find out is pull it up a notch and see it spins when you floor it
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    Rich is correct in that only the rears can disengage, the fronts will always have drive. As mentioned earlier, the S3 is pimarily FWD up until the point that the wheels slip, then the Haldex engages to transfer power/drive to the rear wheels, until all wheels are going at the same speed. The question is drive ratio split between front and rear, which in this case is 50:50 F/R under most extreme conditions.
    [ QUOTE ]
    1. There are situations where near 100% torque transfer to the rear axle
    occur. An example is if the front wheels are on ice and the rear wheels are
    on tarmac. In that case the front wheels have (almost) no grip. In that
    case, the Haldex coupling will transfer all torque to the rear axle and
    prevent front wheel spin. On uniform surfaces however, the coupling can not
    transfer all torque to the rear axle. See below.
    [/ QUOTE ]
    What the quote above means is that with the drive being 50:50, then theoretically, with the Haldex engaged and all four wheels travelling at the same speed and the fronts can't get any grip(front wheels on ice), then all the suppose drive/power is left to the rears if it were in contact with tarmac. Make sense?
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    So what does the blue haldex controller do compared to the standard one
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    Quote Originally Posted by rhubarb4 View Post
    Parts, Accessories, Styling and Performance Tuning for your Audi TT Coupe or TT Roadster
    <tuffty/>
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    Interesting read thanks tuffty, bit of a shocker though when you get to the bottom and see the price lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,568
    innit!
    <tuffty/>
    A3 1.8t Quattro Sport!
    May 2011
    suffolk
    278
    Thread from the dead! lol sure the price has dropped since 2004 lol
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    lol inflation
