Results 1 to 7 of 7
Thread: boost pressure
    Oct 2010
    Port Glasgow
    283
    boost pressure
    after a service my s3 has only one problem on the diagnostics= boost reads 990 mbr instead of an expected 950 mbr , what does this mean ??
    secondly i fitted new stat n coolant cpl of wks ago all was fine untill i fitted the new plugs and gapped them to 7mm , ( old plugs were same brand gap was 9-10mm)
    today i noticed the temp gauge climb too 100 deg where as before it only went too 95 deg before the fan cut in ..
    advice greatly appreciated guys ???
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Did you bleed the cooling system could be an air blockage. Not sure about the boost though.
    Welly's Avatar
    Testing dodgy Chinese gear...
    Aug 2009
    Gloucestershire
    10,680
    Quote Originally Posted by Duktor View Post
    Any fault codes to do with over boost?
    We're only talking .04 bar here, which is 0.5 psi. That's nothing to worry about.... Actuator may be a little slow to react, but if there is no fault codes, then meh.
    Homer Simpson
    Wellyboots, you are quite literally my most favourite pikey in the entire world
    Oct 2010
    Port Glasgow
    283
    Quote Originally Posted by bengal View Post
    yeah spent a bit of time doing it as well unscrewed the expantion tank n propped it up put heater on full blast and ran the engine to 2500 rpm for a gd 10 - 15 mins , where does the fan get its signal to come on ive heard there are a few temp sensors on the car but no idea where they are ?
    Oct 2010
    Port Glasgow
    283
    nah no fault code Welly , where is the actuator ? and what is the standard plug gap meant to be ?
    www.badger5.co.uk
    May 2004
    nr Glos
    6,939
    .7mm gap is ok
    the mb output is proportional to the weather... Its an absolute Pressure Sensor, and is reading atmospheric pressure as well as +ve pressure when under boost
    different day, different weather, different pressure
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Oct 2010
    Port Glasgow
    283
    thganks all for replies
