AH FabricationsBadger5
    May 2010
    71
    Coding Concert 2 to my A3
    Hi all, I have got a audi concert 2 head unit. I think its possible to code it from 'standard' mode to 'bose' mode (which my car has). Does anyone know what the correct code is?
    Accordig to the link here: Waks Wide Web i *think* its 04332. Can anyone confirm this?
    Jun 2003
    World of my own
    9,813
    There is no coding for Bose. The only code is to turn on the Bose welcome when you turn the unit on, which is purely cosmetic.
    If you have Bose then you will have the earth wire on the wiring loom for the Bose pin which puts the HU into Bose flat EQ mode, to restrict the effect of the treble & bass control for that mellow woolly Bose sound, nothing else is needed.
    Alex Turner
    May 2010
    71
    Hmm i applied that above code and there was no bose welcome.
    Could you elaborate on the bose pin? I just plugged the different plugs that were plugged into my concert 1 into the concert 2 (via one of those canbus adaptors) and it seems to work ok?
    Jun 2003
    World of my own
    9,813
    That's all you have to do, no coding needed
    Alex Turner
