Chris NottAH Fabrications
Results 1 to 9 of 9
    vetch's Avatar
    S3
    Apr 2009
    412
    Front wheel is very loose/has alot of play in it
    There is a lot of play in the wheel, by that I mean that if you jack the car up, there is a good 2cm+ of play in the wheel. The wheel can be "wiggled" on the hub.
    The wheel is securely bolted to the hub, the whole wheel, brake disc etc wiggles as one. I don't believe its the driveshaft as it seems solid and its just had a new balljoint.
    So what else could cause such dangerous play in the wheel? Wheel bearing?
    Audi S3
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    Bearing sounds a good call
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Lower shock mount?
    Is the new balljoint tight...
    vetch's Avatar
    S3
    Apr 2009
    412
    Thanks for your quick replies gents.
    I am certain the balljoint is tight, there doesn't seem to be any movement from it. I had the car on axle stands earlier and you can move the wheel/hub back and forth with minimal effort, its proper loose (and proper dangerous). Im hoping it is just the wheel bearing as its a relatively easy job.
    Its had new shocks and springs and top mounts in the last last few months.
    Audi S3
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    is the play top to bottom, or left to right?.
    If left to right could be a trackrod end.
    vetch's Avatar
    S3
    Apr 2009
    412
    It's top to bottom.
    Audi S3
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    That will be that driveshaft nut again mate, the big 32mm one. Its been loose that last few times, I even loctited it last time. Tighten it up for now, and get a new nut from Audi.
    vetch's Avatar
    S3
    Apr 2009
    412
    Hi Mark, I was hoping you would see this thread. I had a look at that nut, as I remembered you had to loctite it last time. Is it a common problem for this nut to fail/work loose?
    Audi S3
    Apr 2004
    12,500
    Not normally, but your car is far from the Norm.. Take a look mate, i am 99% its that.
    You shoulda texted me or summat
