AH FabricationsJMB Retrofits
Results 1 to 8 of 8
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Central locking pump
    Hi,
    Does anyone know the part number for an 8L S3 Central locking pump.
    How much is one of these fitted? Is it a long job??
    Thanks.
    2001 AMK ...Black
    Oct 2008
    77
    Hi
    There about 250 from Audi then they have to be programmed to your car as they have the immobiliser built in.
    What normally breaks is the graphite impeller which is quit easy to replace, either buy the kit from eBay or a whole unit and strip out the parts wanted like I did
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Mine is still working, however it has just started ticking... constantly, even when the ignition is off.... quite confused.... Any ideas?
    2001 AMK ...Black
    Oct 2008
    77
    Mine Took ages to open the locks I could just hear he motor working trying to build up pressure
    Evenually it did pack up
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Mine is a bit like that, however the ticking only started today and is a bit weird...
    2001 AMK ...Black
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Any other thoughts??
    2001 AMK ...Black
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    742
    Not got a part number as it was paid for by Warranty Direct in June, but it cost 535.76 fitted by Audi Plymouth. Glad I wasnt paying for it, If i had I would have tried one of the eBay repair kits as it was the carbon discs indie that had given up the ghost.
    Hoppe this helps
    Nige
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    landopanda's Avatar
    Apr 2009
    Wiltshire
    143
    Oh dear, thanks for that though.
    The weird thing is the central locking etc is all working fine still. Just this noise coming from the pump.
    2001 AMK ...Black
