[ QUOTE ]
jedi-knight83 said:
WTF
these cars are supposed to be good at cornering. but i come into a roundabout doing the same speed as my corrado and it understeers lots lots more!!
how can i stop this? cause there is no way im keeping the car if it handles this bad! /ubbthreads/images/graemlins/burningmad.gif
camber adjustments should sort it??
has anyone else done anything about it??
ta
[/ QUOTE ]
The only way to 'fix' it is to change the lot...springs, dampers, ARBs and suspension settings.
That works...but costs.
If you do the lot, you'll have a car that will stick with the best of the Evos and Subarus on the twisties though...from experience!
To be honest...the main problem is likely to be your driving style.
The S3 respons well to slow in, fast out...different style to the Corrado...I know, I've had both.
If you brake, get back on the power as you turn in, and make the Haldex work, you'll get rid of a lot of the understeer...you just have to make the chassis work.
Carrying more corner speed under power needs better tyres, suspension and front negative camber...
If you up your rear tyre pressures (to somewhrer near the settings for 4 passengers) and leavce the fronts relatively soft (say, the setting for 2 passengers) you will get a better balance.
Add this to slow in, fast out...and you'll get on better.
Don't forget...quattro doesn't give you any more grip than 2WD.
The corrado runs a lot of front negative camber (about -1.5 degrees per side) and hence has decent grip.
What the quattro gives you is better drive...hence slow in, fast out, and use the drive...
Get it back on boost, get the chassis loaded up, get turned in...and make the ****** thing work!
Very easy to spend money and still have an understeering car...learing how to get the best out of it costs nothing!
