Volks AutosBadger5
Results 1 to 35 of 35
Like Tree1Likes
  • 1 Post By finesse
Thread: How use VAGCOM/VCDS to test for boost & vac leaks
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Looking for help on how to use VAGCOM/VCDS to test for boost & vac leaks?
    stuart_tate41 likes this.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Easiest way is to check block 032.
    There are two fields in the block, and both belong to fuel trims.
    Left hand one is short term adaption, right hand one is long term adaption. Left hand one is the one to look at in this instance.
    Make a note of these two figures. Reset the fault codes (even if there are none), as this will clear the fuel trim data back to 0% for both blocks.
    Then start the motor and log block 032. If the value in the left hand block steadily climbs to or past the 3-4% area, it's normally a good indication of a leak.
    Homer Simpson
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Thanks Welly, you the man
    DaveA3's Avatar
    Audi A-Trizzle!
    Milton Keynes
    2,378
    what should it be if there are no leaks welly mate?
    Audi A3 1.8T Sport (AGU) - 2000
    Engine: Carbonio CAI/Jetex JR Hybrid Induction, Forge 007p DV, Forge TIP, Longlife S/S Custom Exhaust system, R-Tech Stage 1 Remap, Creation Motorsport Boost Pipe Kit.
    Exterior and Chassis: 18" Cades Tyrus, Euro Wipers, low on JOM Coilovers, Eibach Front & Rear ARB's, Black Angel Eye Headlights, 6000K HID's, S3 Brakes.
    For Sale PM ME - £2500 Mods Inc
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by DaveA3 View Post
    As close to 0% as possible..... It means it's neither adding, nor taking away fuel at idle.
    Homer Simpson
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,316
    Will be trying this in the morning!
    Leggy suggested that at 3000rpm under no load the real time MAF reading should be exactly 10g/s on a car with no leaks....
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Not tried this, but did see it. Would be interested to know if it works from someone who's tried it....
    Homer Simpson
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    well, it works in mine. holding the revs as accurately at 3k as I can I see bang on 10g/s, and to my knowledge, I don't have any leaks.
    GOing to check the fuel trims in a mo see what that gives me to confirm
    Essflee's Avatar
    Mar 2008
    2,007
    I did try this too with my mates liquid gauge, held the revs at 3000rpm and I was only showing 8g/s...
    Went to Jabba yesterday and they smoke tested the system and I do have a boost leak by the inlet manifold, going to put the new pipe on Monday as Jabba didn't have the part in stock, once I've done the fix I'll try the liquid gauge again,
    Let you know how I get on...
    revo'd
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    Thanks thats a good bit of info
    117
    Does the 3k rev method and block 032 apply to 1.8t A3's too?
    Essflee's Avatar
    Mar 2008
    2,007
    Quote Originally Posted by nick4501 View Post
    Prawns is an A3 1.8T and it seems to work on his...
    revo'd
    117
    Quote Originally Posted by leggy View Post
    Good point! - Cheers, will give it a try.
    Lloyd149's Avatar
    Dec 2009
    York
    102
    Cheers, will try this too.
    Sticky?
    Danny Cawsey's Avatar
    Cawsey
    Dec 2009
    Valencia, Spain
    491
    what should my boost gauge be reading on idle with a stage two map and forge mbc set to 1.5 bar 1999 aoudi s3 apy?
    its reading -0.7 bar is this correct?
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,316
    Just tried the fuel trims test on mine, before resetting it was -0.4% short term, and -4% long term.
    Reset them and the short term didn't move from 0 at all for 5 mins idling. drove 30 miles home, and short term is 0 still, and long term is -3.9%
    Does this sound fairly normal to you guys?
    If it's pulling out 4% fuel long term, does that imply the map is running rich as standard, and it's possibly got a smallish leak somewhere? or being a generic map, will they all adjust a few % up or down to suit individual cars?
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Short term trim sounds spot on dude.
    Long term trim's acceptable tolerances are between +/-10%, and you are well within that. Bottom line is that it's a generic map, and every engine is different...
    The ECU won't throw the EML for fuelling until +/-25% is breached.
    Homer Simpson
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    I thought the short term adaptation is considered fine -+ 10%?
    Mpathe's Avatar
    1st gear
    Aug 2009
    manchester
    394
    Quote Originally Posted by dannycawsey View Post
    mine reads on idle -20 which i -1.3 bar so you might have leak some where
    09 white black edition a3 2.0 tdi 😃
    99 silver apy s3 - revo stage 2 mapped - relentless downpipe + sports cat - cat back milltek - fmic - piper x panel filter - silicone tip - forge 007 - vmaxx coilys - andy mac stealth sub - wilwood 4pots and r32 discs - h &r spacers - bbs ch wheels or std gunmetal grey alloys
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by finesse View Post
    Yeah.....? I don't understand what you're getting at here dude....
    Homer Simpson
    Sep 2009
    102
    Did both the methods and my results are:
    Rpm at 3000rpm is between 10.3-10.9
    Short term fuel is at 0.8 and long term is at 0 after 5 mins
    Does this look like I have a leak?
    Also, how would my boost gauge behave if there is a leak?
    Audi A4 2.0TFSI Quattro S-line - Stock! (for now)
    Essflee's Avatar
    Mar 2008
    2,007
    Sekenzo,
    Not sure about the fuel trims but the theory of holding 3k revs and your G/s maf reading would suggest that your car is fine, I was told that the tolerance is 0.9, as your seeing 10.9 would suggest your car is fine...
    revo'd
    Feb 2008
    Manchester
    158
    i might sound alittle special here but do you hold 3000rpm stationary or whilst moving(3rd, 4th, 5th Gear)?
    thanks
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,851
    At a standstill.
    Feb 2008
    Manchester
    158
    do you think it would work on a AGU (no MAP sensor)?
    Aug 2010
    1,540
    plus or minus 10% is what the ecu works on.
    if its outside these perameters the management light is supposed to come on showing up fuel trim faults.
    whether these faults are due to air leaks/injector faults/dodgy air mass's is anyones guesses!
  28. #27
    Dec 2010
    12
    Hello everyone this is my first post ive been lurking around the site gathering info to try and resolve 2 faults on a 02 Audi A3 1.8 T AUM engine
    error codes are
    2 Faults Found:
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-00 - -
    17544 - Fuel Trim: Bank 1 (Add): System too Lean
    P1136 - 35-00 -
    up to now i have replaced 2 breather hoses 06A103247 & 06A103213AK
    ordered a Recirculating closed loop Dump Valve which i hope will clear the Boost Pressure Control Valve (N249): Mechanical Malfunction
    just had a look at Block 032 whilst stationary idling at the moment i have a reading of:
    7.9 Idle O2 Adapt & -3.1 Run O2 Adapt
    because the first reading is high could this be because the DV is faulty & creating another vac leak as well as giving no boost pressure ?
    cel comes on after about 15 miles 23 mpg is not good at all even when driving like miss daisy
    update
    Just found another split pipe under inlet manifold it comes out of a T piece to the underside of the inlet manifold I'm not sure about the part number i think its
    06A 133 783 AT could anyone confirm this will fit A3 1.8 T AUM engine Ive cobbled something together for now to see if it cures:
    17544 - Fuel Trim: Bank 1 (Add): System too Lean fault
  29. #28
    Dec 2010
    12
    Boost Fixed
    Fingers crossed think Ive sorted faults:
    P1200 - 35-00 - -
    P1136 - 35-00 -
    Replaced split vac pipes & old DV
    bought a piston type from ebay see if it lasts longer than a 710N
    Link to before and after boost charts could anyone tell me if 2nd chart looks about right for a standard 1.8T
  30. #29
    vrbob's Avatar
    Jun 2007
    Southampton
    2,361
    Tried this method out yesterday while doing some tinkering with a couple of other guys from here and its a good quick way to check to see if you have any leaks that need investigating furthur.
    My car from the results is looking pretty leak free and held 10g/s at 3k rpm so all is good cheers for the guide chaps
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
  31. #30
    Wingnut Express's Avatar
    Audi sponsored by Mastercard
    Feb 2008
    Surrey
    125
    Hi Guys
    I tried the Block 032 test last night to see if if there were any leaks, but would really appreciate some advice to clarify the results
    I ran the car for a short while to allow it to warm up and then I ran the test.
    -1.3% on the Left - Short Term and - 6.3% on the right - Long term
    I then cleared the faults as suggested and these results differed to the below
    -0.4% rising to -1.7% Short term & 0.0% on the long term
    I already have concerns that the car is running lean, but I do not understand these results enough to be able to make an eductaed decision?
    Sadly it was too late at night to be holding the engine a 3k to test the other way
    Thanks in advance
    Worried that one day I may have to buy something sensible, but until then!
  32. #31
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    -6.3% LTFT is more likely to indicate you have a leak under boost... a vacuum leak will show as a positive figure in STFT but may well adapt to a negative value in LTFT... LTFT's will take a little while to adapt...
    If you suspect you have a fuel issue then you need to log blocks 001, 031 (as you have a wideband ECU on your AMK S3) as this will show lambda control values (001) and requested AFR vs actual AFR (031)...
    <tuffty/>
  33. #32
    Feb 2008
    Surrey
    125
    Thanks Tuffty I will try this again tonight, as I balls up logging Blocks 001 & 031 last night. (driving and clicking go on the laptop!)
    Cheers Ian
  34. #33
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,439
    Quote Originally Posted by Wingnut Express View Post
    Cheers Ian
    Click go before driving off then just look at the run rather than all the surrounding data... safer.. also... hover the mouse over the marker button and tap the tounch pad prior to a run... you can also use the 'right arrow' cursor key too...
    <tuffty/>
  35. #34
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    870
    Add Vex182 on Facebook
    Sorry to drag this up, if I have a positive reading in the left box. The number went from 0 to 3% in a few minutes after resetting, what is that telling me?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  36. #35
    Aug 2009
    Kent
    70
    Probably got a leak, A smoke test would be the next step to find the leak, the 1.8t is well known for leaks.
