AH FabricationsEM Tuning
Results 1 to 14 of 14
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    1.8T Cylinder Head Issues
    I've recently been noticing that 1.8T cylinder heads/gaskets have been failing so i thought i'd start a thread to help others with identifying the symptoms. I have put down some information of mine, essentially all 1.8T heads are the same but it would be interesting to see if there is a pattern with these heads failing
    Car - Audi S3
    Age - 2001
    Mileage - 122,000
    Service History - Serviced every 5-6k using 10w40
    Standard/Mapped - Unknown
    Head - AMK
    Symptoms - Poor starting from cold, excess steam from exhaust, sweet scent from exhaust, loss of coolant, hydrocarbon in expansion tank, wet plugs, slight mayo like substance on oil filler cap
    What was the issue - Crack cylinder head, cracked on 3 exhaust ports
    Reason - No idea
    finesse's Avatar
    Aug 2006
    London / Anglia
    2,814
    Sorry to hear, what is your plan now? Need head, skim..?
    An AGU head + JBS manifold
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Mine's all sorted now John, turbo rebuild next
    Oct 2010
    Port Glasgow
    283
    sorry to hear that m8 Ive got same car same age with 126000 on clock , touch wood my head is fine at mo , do you have any pics of the damaged area ?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by Duktor View Post
    I'll post some images of the old head on the weekend
    Oct 2010
    Port Glasgow
    283
    cool should be an interesting thread if others do same
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yeah, this will be useful.
    Homer Simpson
    barters3's Avatar
    May 2008
    440
    my amk head cracked at around 105k.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Port 1
    Port 2
    Port 3
    Port 1 is furthest away from the fuel pressure regulator
    I haven't cleaned the head up so you can see that the cracks on the exhaust ports has let the coolant basically wash the carbon build up on the inlet side lol Port 4 looks normal
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    A crack between the two valves like that shouldnt really be breaking into a water jacket?
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Glad mine is a large port then.
    Seeing there is only a small port casting and a large, i just can't see why it seems to be an AMK problem.. Maybe due to the performence expected from them?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    What do you mean bud? lol Water jacket?
    Mark > Very strange as to why it seems to be the AMK that's suffering, the BAM is the same but that seems to be holding up
    JamJay's Avatar
    Oct 2010
    Reigate, Surrey
    190
    Thanks for creating this thread, along with this: CRACKED AMK HEAD! it's very helpful. Have their been any instances with cracked AMK heads with lower mileage? It seems that most experience this at 100k+, in which case I have about another 70k to cover before I should see any problems....I hope. As the engine stands now, it's all fine (touch wood) but this info is good to know and not documented on SeatCupra.net.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Its not really mileage thats a problem IMO.... Sandip had my old AMK head off me as I now have a large port head on mine... my AMK head was fine and had done 105k.... The AEB head I have now had done 140k with non of these issues...
    One thing that does happen from a fairly low mileage (60/70k) is the exhaust valve guides wear... this (so I am told) can contribute to valve failure (dropped heads) and subsequently a fair amount of engine damage...
    If you are removing your head for any reason or have a replacement head with some mileage on it I would suggest getting the exhaust guides checked/changed at the least...
    <tuffty/>
Tags for this Thread
