Sky InsuranceBadger5
Results 1 to 16 of 16
    Sep 2010
    maidstone (kent)
    Longitudinal Acceleration Sensor HELP!
    basicly ... its booked into audi to have this replaced on thursday , but ive searched the internet and found exactly were it is and how to change it and ive found somewere to buy one from . But what ive stumbled across is someone saying after replacing it , the sensor will need callibrating..ive only seen this on one post , is this right? . or is it literally plug it in and its all done ? ....help asap before audi take 280 of my moneys!
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Not sure on the calibrating but it will be still cheaper to fit yourself and take it to a garage with vagcom?
    May 2008
    46
    had the same problem and fixed it, did not reset it works fine. Do a search there was a post not long ago. If you dont want to fix it just buy the sensor and change it yourself and save 180 notes.
    It would take audi 15 minutes to do, not a bad hourly rate for them!!!!!!!!!!!
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    i agree with the above. piece of cake. i got sensor for 117.
    leey's Avatar
    Gloucester
    11
    I changed both my longitudinal + latitude sensor on my s3 took about an hour at the most to do, most of the time spent was re-fitting the interior trim panels
    so it lined up sweet.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Definitely a DIY job. If you've got small hands you can even do it without removing the lower dash.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    DIY FTW. Thats a lot of money for a simplistic job.
    Homer Simpson
    Dec 2009
    11
    where is it you are buy it from?
    Need to do mine but dont want to pay Audi for it.
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I think it is a dealer only part.
    Jason
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Has anybody tried taking one apart? has they seem expensive, could they be fixable?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    yes they have, there was a link post on here not long ago to a german fella who had done it and fixed the problem. i took my old one apart though and in the end you'd have to break it out, and re solder it in. weather it will work is a gamble though. il try find the link now.............
    BLUEVISIONS
    there ya go
    Jun 2009
    Woking, Surrey
    131
    Just so we get this straight. The longitudinal is behind the glovebox. The latitudinal is the one under the steering wheel. I fell fowl of this one.
    2001 (Y) Audi S3 AMK | Forge 007p | H&R ARBs | Powerflex Bushes All Round | Badger5 3" TIP & Jetex JR Filter | R-Tech Stage 1 Map | Brembo 4-Pot Callipers (Monoblock from Clio 197) with Ferodo DS2500 & EBC Ultimax Discs | N249 Bypass | Milltek Cat Back Non-Res Special Tips
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    correct. i first thought the other way around, until i unplugged one on steering column and lateral went mad.
    Nov 2010
    scotland east lothian
    46
    Visit westcoast a3's Youtube Channel
    could anyone post some pic of where they are and hat they look like i also have this prob thankx
    Oct 2010
    Port Glasgow
    283
    what do these sensors do and what are they for ?? how would you know if they were faulty ?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    scanning for faults would prove they're faulty, you would get a fault that looks like this...
    01279 - Longitudinal Acceleration Sensor (G251)
    27-10 - Implausible Signal - Intermittent
    also, in the link above that i posted, shows pictures of what they look like.
    the lateral acceleration sensor is located under the steering column to the left of it, its held in a gold bracket, cant miss it, the sensor is put in facing left to right(there is arrows to show its configuration) hence lateral.
    the longitudinal is located behind the glovebox, held in the same bracket, again cant miss this one as there isnt much else. this is configured front to back, hence longitudinal.
    the two sensors are used so that the abs knows how much brake and where to apply it based on your speed and direction. which would explain esp and abs lights coming on.
    hope this helps.
