Volks AutosChris Nott
Thread: oil cap leaking
    Aug 2010
    bradford
    1,252
    oil cap leaking
    hi if i look at a few of my hoses that come off my turbo intake pipe it looks like oil is spraying onto them could my seal have gone tar gaz
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Tbh mate it could be the oil cap or could be the rocker cover gasket or split tip , vac or boost pipes all of these can cause oil to spray around the engine bay. Id have a good look at all of these and go from there.
    Aug 2010
    bradford
    1,252
    cheers my cap moves and is loose plus has oil marks at the bottom of it so think the seal has gone tar
