JMB RetrofitsBadger5
Page 1 of 2 12 LastLast
Results 1 to 40 of 58
    Aug 2010
    118
    Audi S3 cylinder head problems!! 2001 AMK
    hi,
    As discussed on a previous thread i was doing my head gasket etc. I have now removed it at the weekend and the water ports are mega corroded! not a happy chap! It will not skim out so my only thoughts are getting it welded buy a pro and then skim it..(if this is possible?) or hunt for a another head!
    any ideas/help greatly appreciated
    ash
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by stoneys3 View Post
    hi,
    ash
    For piece of mind, slap another head on IMO.
    Any VVT 1.8T engine's head should do. Because it's from the S3, the head will cost more dosh than say an AMK head from a MK4 Golf. Same thing though, and will work fine AFAIK.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    yeah thats what i thought, i would if i had the ability/money to do it all myself
    Alex S3 AMK
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Quote Originally Posted by Cookstein View Post
    ....AGU is large ports though....
    which am the bestest!... ;P
    <tuffty/>
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Word...
    Homer Simpson
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    yep i know, but i dont know if your going from normal small ports to large port if you need to get new intake and exhaust manifolds which the OP might not want the hassle off if he just wants it fixed... but it would be awesome. It is saved in my watch list on ebay along with another large port head i have found
    Alex S3 AMK
    Aug 2010
    118
    hmmmm its says it comes with valves and the lot..but its not shown in the pictures. will my bottom end cope with the big ports ect? very very tempted to buy this!
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    will it need to be remapped going to a large port head?
    Alex S3 AMK
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Everything bolts on the same. You will need a large port inlet manifold gasket though. I used to have an AGU engined A3, so if you do buy this, I'll PM you the reg number so you can get the right gasket.
    Both Tuffty and I are running large port heads on standard 1.8T blocks (except for the forged roads, and mine is in fact a complete AGU engine).
    They fit, they work. End of the day, it's just another 1.8T head.
    EDIT: Adding to this, if you have an AMK engine, you will need to swap your VVT cam chain tensioner over. None of the large port engines came with VVT. So it will not be quite bolt on and go.
    Homer Simpson
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Nope. It's just a head. It will just flow better.
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Lot of money though.... can get large port heads cheaper than that but would still recommend getting the exhaust guides done...
    Not a prob with manifolds... small port stuff from the AMK will bolt straight on... One other thing that should be mentioned is that whatever 20v turbo head you end up with, if it hasn't got VVT you will need to transfer that across... I transferred my followers, cams and VVT over from my old AMK head to the AEB large port I now have....
    I do not know if the non turbo 20v are suitable though and early 20v heads may have a bit that needs machining off where the tensioner pully bolts up due to an earlier design...
    Make sure any head you get has the cam caps that came with that head else you will have issues as they are line bored to the individual heads and don't worry if the head you get has a SAI port as that can be blocked... AMK S3's don't have SAI..
    <tuffty/>
    Aug 2010
    118
    i really wanted a bolt on and go jobby.. but if i can gaim a little from the larger ports ect i mite just go for that and change my stuff over. SAI? whats this, i'm being thick.
    ash
    Aug 2010
    118
    another thing there is a 100 surcharge on that head but i don't think they will except mine as it's foobard!
    ash
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    sai is secondary air injection. You wont have it on your AMK, but the AGU does have it which is why you will have to blank it
    Alex S3 AMK
    Aug 2010
    118
    oh rite cheers. do you think its worth doing in my situation?
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    well if i was in your shoes where i had to go out and buy a new head anyway then yeah i would very very strongly consider it. As it is, my AMK head is fine, yet i still have the large port head saved in my ebay favourites.
    Alex S3 AMK
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    what sort of price are you looking at for a non ported, small port head?
    Alex S3 AMK
    Aug 2010
    118
    duno really cheap as possible really and preferably skimmed and pressure tested. not sure to be honest alot less than the 500 one on ebay as i mite aswell have that othewise.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Another AMK head dies
    What's the mileage on yours stoney?
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    Sounds like it can be repaired
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    Aug 2010
    118
    68000. i brought it bumped, so dint really know wat it was like until it turned up, its now had a full respray and now sorting the engine out lol not drove it properly yet. some nob-head must have kept filling it up with water and ignoring the problems. ohh and the turbo is ****ed!! brought a real pup! but once i sort these few problems should be a minter.
    Aug 2010
    118
    Quote Originally Posted by Andrew@A.L.D View Post
    what mine?? how? who? how much?
    S3 Andy's Avatar
    Mar 2007
    70
    Not sure if this is allowed - but I have an APY head for sale at the moment, have a look in the classifieds.
    Removed from the car on 88k miles (went to an AGU head).
    Comes with everything pictured, but you'd have to swap over your cams, chain + tensioner and blank off the SIA.
    APY head - Audi-Sport.net Classifieds
    Edit: not sure if you'd need the old style coilpacks aswell with this? I had to as the 'bolt down' ones this uses wouldnt fit the my new head... Also have these 4 for sale aswell...
  28. #27
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    did you mean save some pennies?
    Alex S3 AMK
  29. #28
    Aug 2010
    bradford
    1,252
    well ill be saving that guy on ebay and getting a large port head when got some dola looks good
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
  30. #29
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    ^^ I saw it as well before it went. lol
    Homer Simpson
  31. #30
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    lol
    Alex S3 AMK
  32. #31
    Aug 2010
    118
    spoke to the guy who owns the shop, very handy and good to talk too.
  33. #32
    Jun 2009
    Leeds
    3,472
    Yes yours, a good welder and good machinist, me, depends on the damage
    FOR SALE
  34. #33
    Aug 2010
    118
    a bloke has quoted me a good price to repair mine, i will get some pics up tomorrow.
    anyone now of a turbo recondition place as mine has play in and out?
  35. #34
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Homer Simpson
  36. #35
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
  37. #36
    Aug 2010
    118
    cheers guys i wil give them a try tomorrow. cylinder head,cambelt, waterpump and turbo! hopefully after this i shud be problem free lol.
  38. #37
    Aug 2010
    118
    What car does the apt head come off??
  39. #38
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    ...APY?
    Its the early S3 engine, the one before AMK i think
    if you do mean apt, then i have no idea
    Alex S3 AMK
  40. #39
    Aug 2010
    118
    ye am pretty sure its apt?? al av another look tomorrow. this is what i got bak as my reconditioned head today.
  41. #40
    It's all in bits
    Apr 2006
    Bristol
    219
    It's from a Passat. Non turbo 1.8 I think.
  1. Audi S3 2001 AMK.
    By barters3 in forum For Sale/Wanted - Audi Cars
    Last Post: 20th July 2011, 21:19
  2. Cracked AMK cylinder head
    By Sandip in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2010, 20:13
  3. Replies: 7
    Last Post: 15th May 2010, 22:08
  4. Head gasket/ cylinder head worst nightmare!
    By lugz in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2010, 15:52
