AH FabricationsEM Tuning
Thread: Burning Oil
    May 2010
    15
    Burning Oil
    Hey chaps,
    Every time I top up my oil the car puffs out gray smoke. It doesn't happen on turn over, normally when the car gets warm. Any suggestions as to why this would happen after a top up? The oil level is in the middle between minimum and maximum.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hmmm, only thing I can think of is the fact that there has been a lot of oil coming down from the head.
    Whats the engine mileage? Could indicate a stem seal problem, but that would normally occur on start IIRC.
    Homer Simpson
    May 2010
    15
    cheers for the reply welly, 77k
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    If it is smoking when warm and it is the valve stems, it would be terrible on start up, are you using a lot of oil? check the state of your plugs, and do a compression test.
    S3KO4's Avatar
    Aug 2009
    London
    850
    I would say turbo. compressor side seal probabily has gone, you can check for play if you remove the tip. I had the same issue last year. mainly smoke on boost.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
