Results 1 to 9 of 9
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Heated rear windscreen not working
    Hi all,
    Haven't really tested the rear windscreen heater at all since I bought the S3 in April, but this morning I actually needed it. After 5 mins I realised it was doing bugger all. The heated mirrors are all fine, but nothing from the rear screen.
    Is this likely to just be a fuse gone, or are the heatings elements prone to failure?
    '01 Facelift S3. CC'd by the Badger
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    I would say its more than likely a fuse but i would also check the element for breaks i cant see it been anything else though.
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Yeah I hoped so. Can't see anything obviously wrong with the element, so will have to check the fuses. As an electrical retard myself, can someone point me in the direction of the right one(s)?
    S3KO4's Avatar
    Aug 2009
    London
    850
    If it's the element, you can get a touch up pen from ebay which reconects the joints.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Open the drivers door and you can see the end of the dashboard there is a panel which prises off and the fuses are there. You would have to check your handbook for the fuse no for the heated rear window so you know where to find it.
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Cheers, thought it'd be that panel.
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    No problem.
    Keefy's Avatar
    Feb 2009
    Bristol
    124
    Resurrecting this thread as I finally got around to changing the fuse for the rear screen heater. Still no joy, which is a total ball-ache in this weather.
    Seems strange for the whole thing to die - I would've thought individual 'lines' would fail one by one.
    Anyone had this issue and managed to fix it?
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    I'd take a look at the electrical connections on the rear screen and see if they look corroded etc. Get the mutl-meter out and check for any voltage etc
